Patch to make printf/printk work for MBX8xx
peter.o.mueller at gmx.de peter.o.mueller at gmx.de
Fri Jun 8 20:02:56 UTC 2001
Hi,
I have started using C++ with rtems (m68k). I'm not sure but I think that
there is no make-cxx-exe available for the m68k bsp.
I could link my application by just adding stdc++ to LD_LIBS. Is this
equivalent or does the make-cxx-exe script more.
Peter
Machen Sie Ihr Hobby zu Geld bei unserem Partner 1&1!
http://profiseller.de/info/index.php3?ac=OM.PS.PS003K00596T0409a
GMX - Die Kommunikationsplattform im Internet.
http://www.gmx.net
diff -r -c -N rtems/c/src/lib/libbsp/powerpc/mbx8xx/console/console.c rtems.new/c/src/lib/libbsp/powerpc/mbx8xx/console/console.c
*** rtems/c/src/lib/libbsp/powerpc/mbx8xx/console/console.c	Fri Apr  6 17:52:03 2001
--- rtems.new/c/src/lib/libbsp/powerpc/mbx8xx/console/console.c	Tue Jun  5 14:23:45 2001
*** 89,94 ****
--- 89,95 ----
  static rtems_status_code do_poll_write( rtems_device_major_number major, rtems_device_minor_number minor, void * arg);
  static void _BSP_null_char( char c ) {return;}
+ static void serial_putchar(const char c);
  BSP_output_char_function_type BSP_output_char = _BSP_null_char;
*** 518,524 ****
--- 519,709 ----
  	0			/* Boot device logical dev */
+ #define EARLY_CONSOLE
+ #ifdef EARLY_CONSOLE
+ #define MBX_CSR1	((volatile unsigned char *)0xfa100000)
+ #define CSR1_COMEN	(unsigned char)0x02
+ #define PROFF_CONS	PROFF_SMC1
+ #define CPM_CR_CH_CONS	CPM_CR_CH_SMC1
+ #define SMC_INDEX	0
+ #include <bsp/commproc.h>
+ static cpm8xx_t	*cpmp = (cpm8xx_t *)&(((immap_t *)IMAP_ADDR)->im_cpm);
+ void
+ serial_init()
+ 	volatile smc_t		*sp;
+ 	volatile smc_uart_t	*up;
+ 	volatile cbd_t	*tbdf,  *rbdf;
+ 	volatile cpm8xx_t	*cp;
+ 	unsigned int		dpaddr, memaddr;
+ 	bd_t	*bd;
+ 	bd = eppcbugInfo;
+ 	cp = cpmp;
+ 	sp = (smc_t*)&(cp->cp_smc[SMC_INDEX]);
+ 	up = (smc_uart_t *)&cp->cp_dparam[PROFF_CONS];
+ 	/* Disable transmitter/receiver.
+ 	sp->smc_smcmr &= ~(SMCMR_REN | SMCMR_TEN);
+ 	if (*MBX_CSR1 & CSR1_COMEN) {
+ 		/* COM1 is enabled.  Initialize SMC1 and use it for
+ 		 * the console port.
+ 		/* Enable SDMA.
+ 		((immap_t *)IMAP_ADDR)->im_siu_conf.sc_sdcr = 1;
+ 		/* Use Port B for SMCs instead of other functions.
+ 		cp->cp_pbpar |= 0x00000cc0;
+ 		cp->cp_pbdir &= ~0x00000cc0;
+ 		cp->cp_pbodr &= ~0x00000cc0;
+ 		/* Allocate space for two buffer descriptors in the DP ram.
+ 		 * For now, this address seems OK, but it may have to
+ 		 * change with newer versions of the firmware.
+ 		dpaddr = 0x0800;
+ 		/* Grab a few bytes from the top of memory.  EPPC-Bug isn't
+ 		 * running any more, so we can do this.
+ 		memaddr = (bd->bi_memsize - 32) & ~15;
+ 		/* Set the physical address of the host memory buffers in
+ 		 * the buffer descriptors.
+ 		rbdf = (cbd_t *)&cp->cp_dpmem[dpaddr];
+ 		rbdf->cbd_bufaddr = memaddr;
+ 		rbdf->cbd_sc = 0;
+ 		tbdf = rbdf + 1;
+ 		tbdf->cbd_bufaddr = memaddr+4;
+ 		tbdf->cbd_sc = 0;
+ 		/* Set up the uart parameters in the parameter ram.
+ 		up->smc_rbase = dpaddr;
+ 		up->smc_tbase = dpaddr+sizeof(cbd_t);
+ 		up->smc_rfcr = SMC_EB;
+ 		up->smc_tfcr = SMC_EB;
+ 		/* Set UART mode, 8 bit, no parity, one stop.
+ 		 * Enable receive and transmit.
+ 		sp->smc_smcmr = smcr_mk_clen(9) |  SMCMR_SM_UART;
+ 		/* Mask all interrupts and remove anything pending.
+ 		sp->smc_smcm = 0;
+ 		sp->smc_smce = 0xff;
+ 		/* Set up the baud rate generator.
+ 		 * See 8xx_io/commproc.c for details.
+ 		cp->cp_simode = 0x10000000;
+ 		cp->cp_brgc1 =
+ 			((((bd->bi_intfreq * 1000000)/16) / 9600) << 1) | CPM_BRG_EN;
+ 		/* Enable SMC1 for console output.
+ 		*MBX_CSR1 &= ~CSR1_COMEN;
+ 	else {
+ 		/* SMCx is used as console port.
+ 		tbdf = (cbd_t *)&cp->cp_dpmem[up->smc_tbase];
+ 		rbdf = (cbd_t *)&cp->cp_dpmem[up->smc_rbase];
+ 		/* Issue a stop transmit, and wait for it.
+ 		cp->cp_cpcr = mk_cr_cmd(CPM_CR_CH_CONS,
+ 					CPM_CR_STOP_TX) | CPM_CR_FLG;
+ 		while (cp->cp_cpcr & CPM_CR_FLG);
+ 	/* Make the first buffer the only buffer.
+ 	tbdf->cbd_sc |= BD_SC_WRAP;
+ 	rbdf->cbd_sc |= BD_SC_EMPTY | BD_SC_WRAP;
+ 	/* Single character receive.
+ 	up->smc_mrblr = 1;
+ 	up->smc_maxidl = 0;
+ 	/* Initialize Tx/Rx parameters.
+ 	cp->cp_cpcr = mk_cr_cmd(CPM_CR_CH_CONS, CPM_CR_INIT_TRX) | CPM_CR_FLG;
+ 	/* Enable transmitter/receiver.
+ 	sp->smc_smcmr |= SMCMR_REN | SMCMR_TEN;
+ 	BSP_output_char = serial_putchar;
+ void
+ serial_putchar(const char c)
+ 	volatile cbd_t		*tbdf;
+ 	volatile char		*buf;
+ 	up = (smc_uart_t *)&cpmp->cp_dparam[PROFF_CONS];
+ 	tbdf = (cbd_t *)&cpmp->cp_dpmem[up->smc_tbase];
+ 	/* Wait for last character to go.
+ 	buf = (char *)tbdf->cbd_bufaddr;
+ 	while (tbdf->cbd_sc & BD_SC_READY);
+ 	*buf = c;
+ 	tbdf->cbd_datlen = 1;
+ 	tbdf->cbd_sc |= BD_SC_READY;
+ char
+ serial_getc()
+ 	volatile cbd_t		*rbdf;
+ 	char			c;
+ 	rbdf = (cbd_t *)&cpmp->cp_dpmem[up->smc_rbase];
+ 	/* Wait for character to show up.
+ 	buf = (char *)rbdf->cbd_bufaddr;
+ 	while (rbdf->cbd_sc & BD_SC_EMPTY);
+ 	c = *buf;
+ 	rbdf->cbd_sc |= BD_SC_EMPTY;
+ 	return(c);
+ int
+ serial_tstc()
+ 	return(!(rbdf->cbd_sc & BD_SC_EMPTY));
+ #endif
   * BOILERPLATE *
diff -r -c -N rtems/c/src/lib/libbsp/powerpc/mbx8xx/include/commproc.h rtems.new/c/src/lib/libbsp/powerpc/mbx8xx/include/commproc.h
*** rtems/c/src/lib/libbsp/powerpc/mbx8xx/include/commproc.h	Fri Apr  6 17:52:03 2001
--- rtems.new/c/src/lib/libbsp/powerpc/mbx8xx/include/commproc.h	Tue Jun  5 14:17:34 2001
*** 22,51 ****
  /* CPM Command register.
! #define CPM_CR_RST	((ushort)0x8000)
! #define CPM_CR_OPCODE	((ushort)0x0f00)
! #define CPM_CR_CHAN	((ushort)0x00f0)
! #define CPM_CR_FLG	((ushort)0x0001)
  /* Some commands (there are more...later)
! #define CPM_CR_INIT_TRX		((ushort)0x0000)
! #define CPM_CR_INIT_RX		((ushort)0x0001)
! #define CPM_CR_INIT_TX		((ushort)0x0002)
! #define CPM_CR_STOP_TX		((ushort)0x0004)
! #define CPM_CR_RESTART_TX	((ushort)0x0006)
! #define CPM_CR_SET_GADDR	((ushort)0x0008)
  /* Channel numbers.
! #define CPM_CR_CH_SCC1	((ushort)0x0000)
! #define CPM_CR_CH_I2C	((ushort)0x0001)	/* I2C and IDMA1 */
! #define CPM_CR_CH_SCC2	((ushort)0x0004)
! #define CPM_CR_CH_SPI	((ushort)0x0005)	/* SPI / IDMA2 / Timers */
! #define CPM_CR_CH_SCC3	((ushort)0x0008)
! #define CPM_CR_CH_SMC1	((ushort)0x0009)	/* SMC1 / DSP1 */
! #define CPM_CR_CH_SCC4	((ushort)0x000c)
! #define CPM_CR_CH_SMC2	((ushort)0x000d)	/* SMC2 / DSP2 */
  #define mk_cr_cmd(CH, CMD)	((CMD << 8) | (CH << 4))
--- 22,51 ----
! #define CPM_CR_RST	((unsigned short)0x8000)
! #define CPM_CR_OPCODE	((unsigned short)0x0f00)
! #define CPM_CR_CHAN	((unsigned short)0x00f0)
! #define CPM_CR_FLG	((unsigned short)0x0001)
! #define CPM_CR_INIT_TRX		((unsigned short)0x0000)
! #define CPM_CR_INIT_RX		((unsigned short)0x0001)
! #define CPM_CR_INIT_TX		((unsigned short)0x0002)
! #define CPM_CR_STOP_TX		((unsigned short)0x0004)
! #define CPM_CR_RESTART_TX	((unsigned short)0x0006)
! #define CPM_CR_SET_GADDR	((unsigned short)0x0008)
  /* Channel numbers.
! #define CPM_CR_CH_SCC1	((unsigned short)0x0000)
! #define CPM_CR_CH_I2C	((unsigned short)0x0001)	/* I2C and IDMA1 */
! #define CPM_CR_CH_SCC2	((unsigned short)0x0004)
! #define CPM_CR_CH_SPI	((unsigned short)0x0005)	/* SPI / IDMA2 / Timers */
! #define CPM_CR_CH_SCC3	((unsigned short)0x0008)
! #define CPM_CR_CH_SMC1	((unsigned short)0x0009)	/* SMC1 / DSP1 */
! #define CPM_CR_CH_SCC4	((unsigned short)0x000c)
! #define CPM_CR_CH_SMC2	((unsigned short)0x000d)	/* SMC2 / DSP2 */
*** 54,144 ****
   * as data ram for buffer descriptors, which is all we use right now.
   * Currently the first 512 and last 256 bytes are used for microcode.
! #define CPM_DATAONLY_BASE	((uint)0x0800)
! #define CPM_DATAONLY_SIZE	((uint)0x0700)
! #define CPM_DP_NOSPACE		((uint)0x7fffffff)
  /* Export the base address of the communication processor registers
   * and dual port ram.
  extern	cpm8xx_t	*cpmp;		/* Pointer to comm processor */
! uint		m8xx_cpm_dpalloc(uint size);
! uint		m8xx_cpm_hostalloc(uint size);
! void		m8xx_cpm_setbrg(uint brg, uint rate);
  /* Buffer descriptors used by many of the CPM protocols.
  typedef struct cpm_buf_desc {
! 	ushort	cbd_sc;		/* Status and Control */
! 	ushort	cbd_datlen;	/* Data length in buffer */
! 	uint	cbd_bufaddr;	/* Buffer address in host memory */
  } cbd_t;
! #define BD_SC_EMPTY	((ushort)0x8000)	/* Recieve is empty */
! #define BD_SC_READY	((ushort)0x8000)	/* Transmit is ready */
! #define BD_SC_WRAP	((ushort)0x2000)	/* Last buffer descriptor */
! #define BD_SC_INTRPT	((ushort)0x1000)	/* Interrupt on change */
! #define BD_SC_CM	((ushort)0x0200)	/* Continous mode */
! #define BD_SC_ID	((ushort)0x0100)	/* Rec'd too many idles */
! #define BD_SC_P		((ushort)0x0100)	/* xmt preamble */
! #define BD_SC_BR	((ushort)0x0020)	/* Break received */
! #define BD_SC_FR	((ushort)0x0010)	/* Framing error */
! #define BD_SC_PR	((ushort)0x0008)	/* Parity error */
! #define BD_SC_OV	((ushort)0x0002)	/* Overrun */
! #define BD_SC_CD	((ushort)0x0001)	/* ?? */
  /* Parameter RAM offsets.
! #define PROFF_SCC1	((uint)0x0000)
! #define PROFF_SCC2	((uint)0x0100)
! #define PROFF_SCC3	((uint)0x0200)
! #define PROFF_SMC1	((uint)0x0280)
! #define PROFF_SCC4	((uint)0x0300)
! #define PROFF_SMC2	((uint)0x0380)
  /* Define enough so I can at least use the serial port as a UART.
  typedef struct smc_uart {
! 	ushort	smc_rbase;	/* Rx Buffer descriptor base address */
! 	ushort	smc_tbase;	/* Tx Buffer descriptor base address */
! 	u_char	smc_rfcr;	/* Rx function code */
! 	u_char	smc_tfcr;	/* Tx function code */
! 	ushort	smc_mrblr;	/* Max receive buffer length */
! 	uint	smc_rstate;	/* Internal */
! 	uint	smc_idp;	/* Internal */
! 	ushort	smc_rbptr;	/* Internal */
! 	ushort	smc_ibc;	/* Internal */
! 	uint	smc_rxtmp;	/* Internal */
! 	uint	smc_tstate;	/* Internal */
! 	uint	smc_tdp;	/* Internal */
! 	ushort	smc_tbptr;	/* Internal */
! 	ushort	smc_tbc;	/* Internal */
! 	uint	smc_txtmp;	/* Internal */
! 	ushort	smc_maxidl;	/* Maximum idle characters */
! 	ushort	smc_tmpidl;	/* Temporary idle counter */
! 	ushort	smc_brklen;	/* Last received break length */
! 	ushort	smc_brkec;	/* rcv'd break condition counter */
! 	ushort	smc_brkcr;	/* xmt break count register */
! 	ushort	smc_rmask;	/* Temporary bit mask */
  } smc_uart_t;
  /* Function code bits.
! #define SMC_EB	((u_char)0x10)	/* Set big endian byte order */
  /* SMC uart mode register.
! #define	SMCMR_REN	((ushort)0x0001)
! #define SMCMR_TEN	((ushort)0x0002)
! #define SMCMR_DM	((ushort)0x000c)
! #define SMCMR_SM_GCI	((ushort)0x0000)
! #define SMCMR_SM_UART	((ushort)0x0020)
! #define SMCMR_SM_TRANS	((ushort)0x0030)
! #define SMCMR_SM_MASK	((ushort)0x0030)
! #define SMCMR_PM_EVEN	((ushort)0x0100)	/* Even parity, else odd */
! #define SMCMR_PEN	((ushort)0x0200)	/* Parity enable */
! #define SMCMR_SL	((ushort)0x0400)	/* Two stops, else one */
! #define SMCR_CLEN_MASK	((ushort)0x7800)	/* Character length */
  #define smcr_mk_clen(C)	(((C) << 11) & SMCR_CLEN_MASK)
  /* SMC Event and Mask register.
--- 54,144 ----
! #define CPM_DATAONLY_BASE	((unsigned int)0x0800)
! #define CPM_DATAONLY_SIZE	((unsigned int)0x0700)
! #define CPM_DP_NOSPACE		((unsigned int)0x7fffffff)
! unsigned int		m8xx_cpm_dpalloc(unsigned int size);
! unsigned int		m8xx_cpm_hostalloc(unsigned int size);
! void			m8xx_cpm_setbrg(unsigned int brg, unsigned int rate);
! 	unsigned short	cbd_sc;		/* Status and Control */
! 	unsigned short	cbd_datlen;	/* Data length in buffer */
! 	unsigned int	cbd_bufaddr;	/* Buffer address in host memory */
  } cbd_t;
! #define BD_SC_EMPTY	((unsigned short)0x8000)	/* Recieve is empty */
! #define BD_SC_READY	((unsigned short)0x8000)	/* Transmit is ready */
! #define BD_SC_WRAP	((unsigned short)0x2000)	/* Last buffer descriptor */
! #define BD_SC_INTRPT	((unsigned short)0x1000)	/* Interrupt on change */
! #define BD_SC_CM	((unsigned short)0x0200)	/* Continous mode */
! #define BD_SC_ID	((unsigned short)0x0100)	/* Rec'd too many idles */
! #define BD_SC_P		((unsigned short)0x0100)	/* xmt preamble */
! #define BD_SC_BR	((unsigned short)0x0020)	/* Break received */
! #define BD_SC_FR	((unsigned short)0x0010)	/* Framing error */
! #define BD_SC_PR	((unsigned short)0x0008)	/* Parity error */
! #define BD_SC_OV	((unsigned short)0x0002)	/* Overrun */
! #define BD_SC_CD	((unsigned short)0x0001)	/* ?? */
! #define PROFF_SCC1	((unsigned int)0x0000)
! #define PROFF_SCC2	((unsigned int)0x0100)
! #define PROFF_SCC3	((unsigned int)0x0200)
! #define PROFF_SMC1	((unsigned int)0x0280)
! #define PROFF_SCC4	((unsigned int)0x0300)
! #define PROFF_SMC2	((unsigned int)0x0380)
! 	unsigned short	smc_rbase;	/* Rx Buffer descriptor base address */
! 	unsigned short	smc_tbase;	/* Tx Buffer descriptor base address */
! 	unsigned char	smc_rfcr;	/* Rx function code */
! 	unsigned char	smc_tfcr;	/* Tx function code */
! 	unsigned short	smc_mrblr;	/* Max receive buffer length */
! 	unsigned int	smc_rstate;	/* Internal */
! 	unsigned int	smc_idp;	/* Internal */
! 	unsigned short	smc_rbptr;	/* Internal */
! 	unsigned short	smc_ibc;	/* Internal */
! 	unsigned int	smc_rxtmp;	/* Internal */
! 	unsigned int	smc_tstate;	/* Internal */
! 	unsigned int	smc_tdp;	/* Internal */
! 	unsigned short	smc_tbptr;	/* Internal */
! 	unsigned short	smc_tbc;	/* Internal */
! 	unsigned int	smc_txtmp;	/* Internal */
! 	unsigned short	smc_maxidl;	/* Maximum idle characters */
! 	unsigned short	smc_tmpidl;	/* Temporary idle counter */
! 	unsigned short	smc_brklen;	/* Last received break length */
! 	unsigned short	smc_brkec;	/* rcv'd break condition counter */
! 	unsigned short	smc_brkcr;	/* xmt break count register */
! 	unsigned short	smc_rmask;	/* Temporary bit mask */
  } smc_uart_t;
! #define SMC_EB	((unsigned char)0x10)	/* Set big endian byte order */
! #define	SMCMR_REN	((unsigned short)0x0001)
! #define SMCMR_TEN	((unsigned short)0x0002)
! #define SMCMR_DM	((unsigned short)0x000c)
! #define SMCMR_SM_GCI	((unsigned short)0x0000)
! #define SMCMR_SM_UART	((unsigned short)0x0020)
! #define SMCMR_SM_TRANS	((unsigned short)0x0030)
! #define SMCMR_SM_MASK	((unsigned short)0x0030)
! #define SMCMR_PM_EVEN	((unsigned short)0x0100)	/* Even parity, else odd */
! #define SMCMR_PEN	((unsigned short)0x0200)	/* Parity enable */
! #define SMCMR_SL	((unsigned short)0x0400)	/* Two stops, else one */
! #define SMCR_CLEN_MASK	((unsigned short)0x7800)	/* Character length */
*** 150,247 ****
  /* Baud rate generators.
! #define CPM_BRG_RST		((uint)0x00020000)
! #define CPM_BRG_EN		((uint)0x00010000)
! #define CPM_BRG_EXTC_INT	((uint)0x00000000)
! #define CPM_BRG_EXTC_CLK2	((uint)0x00004000)
! #define CPM_BRG_EXTC_CLK6	((uint)0x00008000)
! #define CPM_BRG_ATB		((uint)0x00002000)
! #define CPM_BRG_CD_MASK		((uint)0x00001ffe)
! #define CPM_BRG_DIV16		((uint)0x00000001)
  /* SCCs.
! #define SCC_GSMRH_IRP		((uint)0x00040000)
! #define SCC_GSMRH_GDE		((uint)0x00010000)
! #define SCC_GSMRH_TCRC_CCITT	((uint)0x00008000)
! #define SCC_GSMRH_TCRC_BISYNC	((uint)0x00004000)
! #define SCC_GSMRH_TCRC_HDLC	((uint)0x00000000)
! #define SCC_GSMRH_REVD		((uint)0x00002000)
! #define SCC_GSMRH_TRX		((uint)0x00001000)
! #define SCC_GSMRH_TTX		((uint)0x00000800)
! #define SCC_GSMRH_CDP		((uint)0x00000400)
! #define SCC_GSMRH_CTSP		((uint)0x00000200)
! #define SCC_GSMRH_CDS		((uint)0x00000100)
! #define SCC_GSMRH_CTSS		((uint)0x00000080)
! #define SCC_GSMRH_TFL		((uint)0x00000040)
! #define SCC_GSMRH_RFW		((uint)0x00000020)
! #define SCC_GSMRH_TXSY		((uint)0x00000010)
! #define SCC_GSMRH_SYNL16	((uint)0x0000000c)
! #define SCC_GSMRH_SYNL8		((uint)0x00000008)
! #define SCC_GSMRH_SYNL4		((uint)0x00000004)
! #define SCC_GSMRH_RTSM		((uint)0x00000002)
! #define SCC_GSMRH_RSYN		((uint)0x00000001)
! #define SCC_GSMRL_SIR		((uint)0x80000000)	/* SCC2 only */
! #define SCC_GSMRL_EDGE_NONE	((uint)0x60000000)
! #define SCC_GSMRL_EDGE_NEG	((uint)0x40000000)
! #define SCC_GSMRL_EDGE_POS	((uint)0x20000000)
! #define SCC_GSMRL_EDGE_BOTH	((uint)0x00000000)
! #define SCC_GSMRL_TCI		((uint)0x10000000)
! #define SCC_GSMRL_TSNC_3	((uint)0x0c000000)
! #define SCC_GSMRL_TSNC_4	((uint)0x08000000)
! #define SCC_GSMRL_TSNC_14	((uint)0x04000000)
! #define SCC_GSMRL_TSNC_INF	((uint)0x00000000)
! #define SCC_GSMRL_RINV		((uint)0x02000000)
! #define SCC_GSMRL_TINV		((uint)0x01000000)
! #define SCC_GSMRL_TPL_128	((uint)0x00c00000)
! #define SCC_GSMRL_TPL_64	((uint)0x00a00000)
! #define SCC_GSMRL_TPL_48	((uint)0x00800000)
! #define SCC_GSMRL_TPL_32	((uint)0x00600000)
! #define SCC_GSMRL_TPL_16	((uint)0x00400000)
! #define SCC_GSMRL_TPL_8		((uint)0x00200000)
! #define SCC_GSMRL_TPL_NONE	((uint)0x00000000)
! #define SCC_GSMRL_TPP_ALL1	((uint)0x00180000)
! #define SCC_GSMRL_TPP_01	((uint)0x00100000)
! #define SCC_GSMRL_TPP_10	((uint)0x00080000)
! #define SCC_GSMRL_TPP_ZEROS	((uint)0x00000000)
! #define SCC_GSMRL_TEND		((uint)0x00040000)
! #define SCC_GSMRL_TDCR_32	((uint)0x00030000)
! #define SCC_GSMRL_TDCR_16	((uint)0x00020000)
! #define SCC_GSMRL_TDCR_8	((uint)0x00010000)
! #define SCC_GSMRL_TDCR_1	((uint)0x00000000)
! #define SCC_GSMRL_RDCR_32	((uint)0x0000c000)
! #define SCC_GSMRL_RDCR_16	((uint)0x00008000)
! #define SCC_GSMRL_RDCR_8	((uint)0x00004000)
! #define SCC_GSMRL_RDCR_1	((uint)0x00000000)
! #define SCC_GSMRL_RENC_DFMAN	((uint)0x00003000)
! #define SCC_GSMRL_RENC_MANCH	((uint)0x00002000)
! #define SCC_GSMRL_RENC_FM0	((uint)0x00001000)
! #define SCC_GSMRL_RENC_NRZI	((uint)0x00000800)
! #define SCC_GSMRL_RENC_NRZ	((uint)0x00000000)
! #define SCC_GSMRL_TENC_DFMAN	((uint)0x00000600)
! #define SCC_GSMRL_TENC_MANCH	((uint)0x00000400)
! #define SCC_GSMRL_TENC_FM0	((uint)0x00000200)
! #define SCC_GSMRL_TENC_NRZI	((uint)0x00000100)
! #define SCC_GSMRL_TENC_NRZ	((uint)0x00000000)
! #define SCC_GSMRL_DIAG_LE	((uint)0x000000c0)	/* Loop and echo */
! #define SCC_GSMRL_DIAG_ECHO	((uint)0x00000080)
! #define SCC_GSMRL_DIAG_LOOP	((uint)0x00000040)
! #define SCC_GSMRL_DIAG_NORM	((uint)0x00000000)
! #define SCC_GSMRL_ENR		((uint)0x00000020)
! #define SCC_GSMRL_ENT		((uint)0x00000010)
! #define SCC_GSMRL_MODE_ENET	((uint)0x0000000c)
! #define SCC_GSMRL_MODE_DDCMP	((uint)0x00000009)
! #define SCC_GSMRL_MODE_BISYNC	((uint)0x00000008)
! #define SCC_GSMRL_MODE_V14	((uint)0x00000007)
! #define SCC_GSMRL_MODE_AHDLC	((uint)0x00000006)
! #define SCC_GSMRL_MODE_PROFIBUS	((uint)0x00000005)
! #define SCC_GSMRL_MODE_UART	((uint)0x00000004)
! #define SCC_GSMRL_MODE_SS7	((uint)0x00000003)
! #define SCC_GSMRL_MODE_ATALK	((uint)0x00000002)
! #define SCC_GSMRL_MODE_HDLC	((uint)0x00000000)
! #define SCC_TODR_TOD		((ushort)0x8000)
  /* SCC Event and Mask register.
--- 150,247 ----
! #define CPM_BRG_RST		((unsigned int)0x00020000)
! #define CPM_BRG_EN		((unsigned int)0x00010000)
! #define CPM_BRG_EXTC_INT	((unsigned int)0x00000000)
! #define CPM_BRG_EXTC_CLK2	((unsigned int)0x00004000)
! #define CPM_BRG_EXTC_CLK6	((unsigned int)0x00008000)
! #define CPM_BRG_ATB		((unsigned int)0x00002000)
! #define CPM_BRG_CD_MASK		((unsigned int)0x00001ffe)
! #define CPM_BRG_DIV16		((unsigned int)0x00000001)
  /* SCCs.
! #define SCC_GSMRH_IRP		((unsigned int)0x00040000)
! #define SCC_GSMRH_GDE		((unsigned int)0x00010000)
! #define SCC_GSMRH_TCRC_CCITT	((unsigned int)0x00008000)
! #define SCC_GSMRH_TCRC_BISYNC	((unsigned int)0x00004000)
! #define SCC_GSMRH_TCRC_HDLC	((unsigned int)0x00000000)
! #define SCC_GSMRH_REVD		((unsigned int)0x00002000)
! #define SCC_GSMRH_TRX		((unsigned int)0x00001000)
! #define SCC_GSMRH_TTX		((unsigned int)0x00000800)
! #define SCC_GSMRH_CDP		((unsigned int)0x00000400)
! #define SCC_GSMRH_CTSP		((unsigned int)0x00000200)
! #define SCC_GSMRH_CDS		((unsigned int)0x00000100)
! #define SCC_GSMRH_CTSS		((unsigned int)0x00000080)
! #define SCC_GSMRH_TFL		((unsigned int)0x00000040)
! #define SCC_GSMRH_RFW		((unsigned int)0x00000020)
! #define SCC_GSMRH_TXSY		((unsigned int)0x00000010)
! #define SCC_GSMRH_SYNL16	((unsigned int)0x0000000c)
! #define SCC_GSMRH_SYNL8		((unsigned int)0x00000008)
! #define SCC_GSMRH_SYNL4		((unsigned int)0x00000004)
! #define SCC_GSMRH_RTSM		((unsigned int)0x00000002)
! #define SCC_GSMRH_RSYN		((unsigned int)0x00000001)
! #define SCC_GSMRL_SIR		((unsigned int)0x80000000)	/* SCC2 only */
! #define SCC_GSMRL_EDGE_NONE	((unsigned int)0x60000000)
! #define SCC_GSMRL_EDGE_NEG	((unsigned int)0x40000000)
! #define SCC_GSMRL_EDGE_POS	((unsigned int)0x20000000)
! #define SCC_GSMRL_EDGE_BOTH	((unsigned int)0x00000000)
! #define SCC_GSMRL_TCI		((unsigned int)0x10000000)
! #define SCC_GSMRL_TSNC_3	((unsigned int)0x0c000000)
! #define SCC_GSMRL_TSNC_4	((unsigned int)0x08000000)
! #define SCC_GSMRL_TSNC_14	((unsigned int)0x04000000)
! #define SCC_GSMRL_TSNC_INF	((unsigned int)0x00000000)
! #define SCC_GSMRL_RINV		((unsigned int)0x02000000)
! #define SCC_GSMRL_TINV		((unsigned int)0x01000000)
! #define SCC_GSMRL_TPL_128	((unsigned int)0x00c00000)
! #define SCC_GSMRL_TPL_64	((unsigned int)0x00a00000)
! #define SCC_GSMRL_TPL_48	((unsigned int)0x00800000)
! #define SCC_GSMRL_TPL_32	((unsigned int)0x00600000)
! #define SCC_GSMRL_TPL_16	((unsigned int)0x00400000)
! #define SCC_GSMRL_TPL_8		((unsigned int)0x00200000)
! #define SCC_GSMRL_TPL_NONE	((unsigned int)0x00000000)
! #define SCC_GSMRL_TPP_ALL1	((unsigned int)0x00180000)
! #define SCC_GSMRL_TPP_01	((unsigned int)0x00100000)
! #define SCC_GSMRL_TPP_10	((unsigned int)0x00080000)
! #define SCC_GSMRL_TPP_ZEROS	((unsigned int)0x00000000)
! #define SCC_GSMRL_TEND		((unsigned int)0x00040000)
! #define SCC_GSMRL_TDCR_32	((unsigned int)0x00030000)
! #define SCC_GSMRL_TDCR_16	((unsigned int)0x00020000)
! #define SCC_GSMRL_TDCR_8	((unsigned int)0x00010000)
! #define SCC_GSMRL_TDCR_1	((unsigned int)0x00000000)
! #define SCC_GSMRL_RDCR_32	((unsigned int)0x0000c000)
! #define SCC_GSMRL_RDCR_16	((unsigned int)0x00008000)
! #define SCC_GSMRL_RDCR_8	((unsigned int)0x00004000)
! #define SCC_GSMRL_RDCR_1	((unsigned int)0x00000000)
! #define SCC_GSMRL_RENC_DFMAN	((unsigned int)0x00003000)
! #define SCC_GSMRL_RENC_MANCH	((unsigned int)0x00002000)
! #define SCC_GSMRL_RENC_FM0	((unsigned int)0x00001000)
! #define SCC_GSMRL_RENC_NRZI	((unsigned int)0x00000800)
! #define SCC_GSMRL_RENC_NRZ	((unsigned int)0x00000000)
! #define SCC_GSMRL_TENC_DFMAN	((unsigned int)0x00000600)
! #define SCC_GSMRL_TENC_MANCH	((unsigned int)0x00000400)
! #define SCC_GSMRL_TENC_FM0	((unsigned int)0x00000200)
! #define SCC_GSMRL_TENC_NRZI	((unsigned int)0x00000100)
! #define SCC_GSMRL_TENC_NRZ	((unsigned int)0x00000000)
! #define SCC_GSMRL_DIAG_LE	((unsigned int)0x000000c0)	/* Loop and echo */
! #define SCC_GSMRL_DIAG_ECHO	((unsigned int)0x00000080)
! #define SCC_GSMRL_DIAG_LOOP	((unsigned int)0x00000040)
! #define SCC_GSMRL_DIAG_NORM	((unsigned int)0x00000000)
! #define SCC_GSMRL_ENR		((unsigned int)0x00000020)
! #define SCC_GSMRL_ENT		((unsigned int)0x00000010)
! #define SCC_GSMRL_MODE_ENET	((unsigned int)0x0000000c)
! #define SCC_GSMRL_MODE_DDCMP	((unsigned int)0x00000009)
! #define SCC_GSMRL_MODE_BISYNC	((unsigned int)0x00000008)
! #define SCC_GSMRL_MODE_V14	((unsigned int)0x00000007)
! #define SCC_GSMRL_MODE_AHDLC	((unsigned int)0x00000006)
! #define SCC_GSMRL_MODE_PROFIBUS	((unsigned int)0x00000005)
! #define SCC_GSMRL_MODE_UART	((unsigned int)0x00000004)
! #define SCC_GSMRL_MODE_SS7	((unsigned int)0x00000003)
! #define SCC_GSMRL_MODE_ATALK	((unsigned int)0x00000002)
! #define SCC_GSMRL_MODE_HDLC	((unsigned int)0x00000000)
! #define SCC_TODR_TOD		((unsigned short)0x8000)
*** 251,332 ****
  #define	SCCM_RX		((unsigned char)0x01)
  typedef struct scc_param {
! 	ushort	scc_rbase;	/* Rx Buffer descriptor base address */
! 	ushort	scc_tbase;	/* Tx Buffer descriptor base address */
! 	u_char	scc_rfcr;	/* Rx function code */
! 	u_char	scc_tfcr;	/* Tx function code */
! 	ushort	scc_mrblr;	/* Max receive buffer length */
! 	uint	scc_rstate;	/* Internal */
! 	uint	scc_idp;	/* Internal */
! 	ushort	scc_rbptr;	/* Internal */
! 	ushort	scc_ibc;	/* Internal */
! 	uint	scc_rxtmp;	/* Internal */
! 	uint	scc_tstate;	/* Internal */
! 	uint	scc_tdp;	/* Internal */
! 	ushort	scc_tbptr;	/* Internal */
! 	ushort	scc_tbc;	/* Internal */
! 	uint	scc_txtmp;	/* Internal */
! 	uint	scc_rcrc;	/* Internal */
! 	uint	scc_tcrc;	/* Internal */
  } sccp_t;
! #define SCC_EB	((u_char)0x10)	/* Set big endian byte order */
  /* CPM Ethernet through SCC1.
  typedef struct scc_enet {
  	sccp_t	sen_genscc;
! 	uint	sen_cpres;	/* Preset CRC */
! 	uint	sen_cmask;	/* Constant mask for CRC */
! 	uint	sen_crcec;	/* CRC Error counter */
! 	uint	sen_alec;	/* alignment error counter */
! 	uint	sen_disfc;	/* discard frame counter */
! 	ushort	sen_pads;	/* Tx short frame pad character */
! 	ushort	sen_retlim;	/* Retry limit threshold */
! 	ushort	sen_retcnt;	/* Retry limit counter */
! 	ushort	sen_maxflr;	/* maximum frame length register */
! 	ushort	sen_minflr;	/* minimum frame length register */
! 	ushort	sen_maxd1;	/* maximum DMA1 length */
! 	ushort	sen_maxd2;	/* maximum DMA2 length */
! 	ushort	sen_maxd;	/* Rx max DMA */
! 	ushort	sen_dmacnt;	/* Rx DMA counter */
! 	ushort	sen_maxb;	/* Max BD byte count */
! 	ushort	sen_gaddr1;	/* Group address filter */
! 	ushort	sen_gaddr2;
! 	ushort	sen_gaddr3;
! 	ushort	sen_gaddr4;
! 	uint	sen_tbuf0data0;	/* Save area 0 - current frame */
! 	uint	sen_tbuf0data1;	/* Save area 1 - current frame */
! 	uint	sen_tbuf0rba;	/* Internal */
! 	uint	sen_tbuf0crc;	/* Internal */
! 	ushort	sen_tbuf0bcnt;	/* Internal */
! 	ushort	sen_paddrh;	/* physical address (MSB) */
! 	ushort	sen_paddrm;
! 	ushort	sen_paddrl;	/* physical address (LSB) */
! 	ushort	sen_pper;	/* persistence */
! 	ushort	sen_rfbdptr;	/* Rx first BD pointer */
! 	ushort	sen_tfbdptr;	/* Tx first BD pointer */
! 	ushort	sen_tlbdptr;	/* Tx last BD pointer */
! 	uint	sen_tbuf1data0;	/* Save area 0 - current frame */
! 	uint	sen_tbuf1data1;	/* Save area 1 - current frame */
! 	uint	sen_tbuf1rba;	/* Internal */
! 	uint	sen_tbuf1crc;	/* Internal */
! 	ushort	sen_tbuf1bcnt;	/* Internal */
! 	ushort	sen_txlen;	/* Tx Frame length counter */
! 	ushort	sen_iaddr1;	/* Individual address filter */
! 	ushort	sen_iaddr2;
! 	ushort	sen_iaddr3;
! 	ushort	sen_iaddr4;
! 	ushort	sen_boffcnt;	/* Backoff counter */
  	/* NOTE: Some versions of the manual have the following items
  	 * incorrectly documented.  Below is the proper order.
! 	ushort	sen_taddrh;	/* temp address (MSB) */
! 	ushort	sen_taddrm;
! 	ushort	sen_taddrl;	/* temp address (LSB) */
  } scc_enet_t;
  /* Bits in parallel I/O port registers that have to be set/cleared
--- 251,332 ----
! 	unsigned short	scc_rbase;	/* Rx Buffer descriptor base address */
! 	unsigned short	scc_tbase;	/* Tx Buffer descriptor base address */
! 	unsigned char	scc_rfcr;	/* Rx function code */
! 	unsigned char	scc_tfcr;	/* Tx function code */
! 	unsigned short	scc_mrblr;	/* Max receive buffer length */
! 	unsigned int	scc_rstate;	/* Internal */
! 	unsigned int	scc_idp;	/* Internal */
! 	unsigned short	scc_rbptr;	/* Internal */
! 	unsigned short	scc_ibc;	/* Internal */
! 	unsigned int	scc_rxtmp;	/* Internal */
! 	unsigned int	scc_tstate;	/* Internal */
! 	unsigned int	scc_tdp;	/* Internal */
! 	unsigned short	scc_tbptr;	/* Internal */
! 	unsigned short	scc_tbc;	/* Internal */
! 	unsigned int	scc_txtmp;	/* Internal */
! 	unsigned int	scc_rcrc;	/* Internal */
! 	unsigned int	scc_tcrc;	/* Internal */
  } sccp_t;
! #define SCC_EB	((unsigned char)0x10)	/* Set big endian byte order */
  	sccp_t	sen_genscc;
! 	unsigned int	sen_cpres;	/* Preset CRC */
! 	unsigned int	sen_cmask;	/* Constant mask for CRC */
! 	unsigned int	sen_crcec;	/* CRC Error counter */
! 	unsigned int	sen_alec;	/* alignment error counter */
! 	unsigned int	sen_disfc;	/* discard frame counter */
! 	unsigned short	sen_pads;	/* Tx short frame pad character */
! 	unsigned short	sen_retlim;	/* Retry limit threshold */
! 	unsigned short	sen_retcnt;	/* Retry limit counter */
! 	unsigned short	sen_maxflr;	/* maximum frame length register */
! 	unsigned short	sen_minflr;	/* minimum frame length register */
! 	unsigned short	sen_maxd1;	/* maximum DMA1 length */
! 	unsigned short	sen_maxd2;	/* maximum DMA2 length */
! 	unsigned short	sen_maxd;	/* Rx max DMA */
! 	unsigned short	sen_dmacnt;	/* Rx DMA counter */
! 	unsigned short	sen_maxb;	/* Max BD byte count */
! 	unsigned short	sen_gaddr1;	/* Group address filter */
! 	unsigned short	sen_gaddr2;
! 	unsigned short	sen_gaddr3;
! 	unsigned short	sen_gaddr4;
! 	unsigned int	sen_tbuf0data0;	/* Save area 0 - current frame */
! 	unsigned int	sen_tbuf0data1;	/* Save area 1 - current frame */
! 	unsigned int	sen_tbuf0rba;	/* Internal */
! 	unsigned int	sen_tbuf0crc;	/* Internal */
! 	unsigned short	sen_tbuf0bcnt;	/* Internal */
! 	unsigned short	sen_paddrh;	/* physical address (MSB) */
! 	unsigned short	sen_paddrm;
! 	unsigned short	sen_paddrl;	/* physical address (LSB) */
! 	unsigned short	sen_pper;	/* persistence */
! 	unsigned short	sen_rfbdptr;	/* Rx first BD pointer */
! 	unsigned short	sen_tfbdptr;	/* Tx first BD pointer */
! 	unsigned short	sen_tlbdptr;	/* Tx last BD pointer */
! 	unsigned int	sen_tbuf1data0;	/* Save area 0 - current frame */
! 	unsigned int	sen_tbuf1data1;	/* Save area 1 - current frame */
! 	unsigned int	sen_tbuf1rba;	/* Internal */
! 	unsigned int	sen_tbuf1crc;	/* Internal */
! 	unsigned short	sen_tbuf1bcnt;	/* Internal */
! 	unsigned short	sen_txlen;	/* Tx Frame length counter */
! 	unsigned short	sen_iaddr1;	/* Individual address filter */
! 	unsigned short	sen_iaddr2;
! 	unsigned short	sen_iaddr3;
! 	unsigned short	sen_iaddr4;
! 	unsigned short	sen_boffcnt;	/* Backoff counter */
! 	unsigned short	sen_taddrh;	/* temp address (MSB) */
! 	unsigned short	sen_taddrm;
! 	unsigned short	sen_taddrl;	/* temp address (LSB) */
  } scc_enet_t;
*** 335,479 ****
   * used, and the MPC860 cookbook manual has an example using different
   * clock pins.
! #define PA_ENET_RXD	((ushort)0x0001)
! #define PA_ENET_TXD	((ushort)0x0002)
! #define PA_ENET_TCLK	((ushort)0x0200)
! #define PA_ENET_RCLK	((ushort)0x0800)
! #define PC_ENET_TENA	((ushort)0x0001)
! #define PC_ENET_CLSN	((ushort)0x0010)
! #define PC_ENET_RENA	((ushort)0x0020)
  /* Control bits in the SICR to route TCLK (CLK2) and RCLK (CLK4) to
   * SCC1.  Also, make sure GR1 (bit 24) and SC1 (bit 25) are zero.
! #define SICR_ENET_MASK	((uint)0x000000ff)
! #define SICR_ENET_CLKRT	((uint)0x0000003d)
  /* SCC Event register as used by Ethernet.
! #define SCCE_ENET_GRA	((ushort)0x0080)	/* Graceful stop complete */
! #define SCCE_ENET_TXE	((ushort)0x0010)	/* Transmit Error */
! #define SCCE_ENET_RXF	((ushort)0x0008)	/* Full frame received */
! #define SCCE_ENET_BSY	((ushort)0x0004)	/* All incoming buffers full */
! #define SCCE_ENET_TXB	((ushort)0x0002)	/* A buffer was transmitted */
! #define SCCE_ENET_RXB	((ushort)0x0001)	/* A buffer was received */
  /* SCC Mode Register (PMSR) as used by Ethernet.
! #define SCC_PMSR_HBC	((ushort)0x8000)	/* Enable heartbeat */
! #define SCC_PMSR_FC	((ushort)0x4000)	/* Force collision */
! #define SCC_PMSR_RSH	((ushort)0x2000)	/* Receive short frames */
! #define SCC_PMSR_IAM	((ushort)0x1000)	/* Check individual hash */
! #define SCC_PMSR_ENCRC	((ushort)0x0800)	/* Ethernet CRC mode */
! #define SCC_PMSR_PRO	((ushort)0x0200)	/* Promiscuous mode */
! #define SCC_PMSR_BRO	((ushort)0x0100)	/* Catch broadcast pkts */
! #define SCC_PMSR_SBT	((ushort)0x0080)	/* Special backoff timer */
! #define SCC_PMSR_LPB	((ushort)0x0040)	/* Set Loopback mode */
! #define SCC_PMSR_SIP	((ushort)0x0020)	/* Sample Input Pins */
! #define SCC_PMSR_LCW	((ushort)0x0010)	/* Late collision window */
! #define SCC_PMSR_NIB22	((ushort)0x000a)	/* Start frame search */
! #define SCC_PMSR_FDE	((ushort)0x0001)	/* Full duplex enable */
  /* Buffer descriptor control/status used by Ethernet receive.
! #define BD_ENET_RX_EMPTY	((ushort)0x8000)
! #define BD_ENET_RX_WRAP		((ushort)0x2000)
! #define BD_ENET_RX_INTR		((ushort)0x1000)
! #define BD_ENET_RX_LAST		((ushort)0x0800)
! #define BD_ENET_RX_FIRST	((ushort)0x0400)
! #define BD_ENET_RX_MISS		((ushort)0x0100)
! #define BD_ENET_RX_LG		((ushort)0x0020)
! #define BD_ENET_RX_NO		((ushort)0x0010)
! #define BD_ENET_RX_SH		((ushort)0x0008)
! #define BD_ENET_RX_CR		((ushort)0x0004)
! #define BD_ENET_RX_OV		((ushort)0x0002)
! #define BD_ENET_RX_CL		((ushort)0x0001)
! #define BD_ENET_RX_STATS	((ushort)0x013f)	/* All status bits */
  /* Buffer descriptor control/status used by Ethernet transmit.
! #define BD_ENET_TX_READY	((ushort)0x8000)
! #define BD_ENET_TX_PAD		((ushort)0x4000)
! #define BD_ENET_TX_WRAP		((ushort)0x2000)
! #define BD_ENET_TX_INTR		((ushort)0x1000)
! #define BD_ENET_TX_LAST		((ushort)0x0800)
! #define BD_ENET_TX_TC		((ushort)0x0400)
! #define BD_ENET_TX_DEF		((ushort)0x0200)
! #define BD_ENET_TX_HB		((ushort)0x0100)
! #define BD_ENET_TX_LC		((ushort)0x0080)
! #define BD_ENET_TX_RL		((ushort)0x0040)
! #define BD_ENET_TX_RCMASK	((ushort)0x003c)
! #define BD_ENET_TX_UN		((ushort)0x0002)
! #define BD_ENET_TX_CSL		((ushort)0x0001)
! #define BD_ENET_TX_STATS	((ushort)0x03ff)	/* All status bits */
  /* SCC as UART
  typedef struct scc_uart {
  	sccp_t	scc_genscc;
! 	uint	scc_res1;	/* Reserved */
! 	uint	scc_res2;	/* Reserved */
! 	ushort	scc_maxidl;	/* Maximum idle chars */
! 	ushort	scc_idlc;	/* temp idle counter */
! 	ushort	scc_brkcr;	/* Break count register */
! 	ushort	scc_parec;	/* receive parity error counter */
! 	ushort	scc_frmec;	/* receive framing error counter */
! 	ushort	scc_nosec;	/* receive noise counter */
! 	ushort	scc_brkec;	/* receive break condition counter */
! 	ushort	scc_brkln;	/* last received break length */
! 	ushort	scc_uaddr1;	/* UART address character 1 */
! 	ushort	scc_uaddr2;	/* UART address character 2 */
! 	ushort	scc_rtemp;	/* Temp storage */
! 	ushort	scc_toseq;	/* Transmit out of sequence char */
! 	ushort	scc_char1;	/* control character 1 */
! 	ushort	scc_char2;	/* control character 2 */
! 	ushort	scc_char3;	/* control character 3 */
! 	ushort	scc_char4;	/* control character 4 */
! 	ushort	scc_char5;	/* control character 5 */
! 	ushort	scc_char6;	/* control character 6 */
! 	ushort	scc_char7;	/* control character 7 */
! 	ushort	scc_char8;	/* control character 8 */
! 	ushort	scc_rccm;	/* receive control character mask */
! 	ushort	scc_rccr;	/* receive control character register */
! 	ushort	scc_rlbc;	/* receive last break character */
  } scc_uart_t;
  /* SCC Event and Mask registers when it is used as a UART.
! #define UART_SCCM_GLR		((ushort)0x1000)
! #define UART_SCCM_GLT		((ushort)0x0800)
! #define UART_SCCM_AB		((ushort)0x0200)
! #define UART_SCCM_IDL		((ushort)0x0100)
! #define UART_SCCM_GRA		((ushort)0x0080)
! #define UART_SCCM_BRKE		((ushort)0x0040)
! #define UART_SCCM_BRKS		((ushort)0x0020)
! #define UART_SCCM_CCR		((ushort)0x0008)
! #define UART_SCCM_BSY		((ushort)0x0004)
! #define UART_SCCM_TX		((ushort)0x0002)
! #define UART_SCCM_RX		((ushort)0x0001)
  /* The SCC PMSR when used as a UART.
! #define SCU_PMSR_FLC		((ushort)0x8000)
! #define SCU_PMSR_SL		((ushort)0x4000)
! #define SCU_PMSR_CL		((ushort)0x3000)
! #define SCU_PMSR_UM		((ushort)0x0c00)
! #define SCU_PMSR_FRZ		((ushort)0x0200)
! #define SCU_PMSR_RZS		((ushort)0x0100)
! #define SCU_PMSR_SYN		((ushort)0x0080)
! #define SCU_PMSR_DRT		((ushort)0x0040)
! #define SCU_PMSR_PEN		((ushort)0x0010)
! #define SCU_PMSR_RPM		((ushort)0x000c)
! #define SCU_PMSR_REVP		((ushort)0x0008)
! #define SCU_PMSR_TPM		((ushort)0x0003)
! #define SCU_PMSR_TEVP		((ushort)0x0003)
  /* CPM Transparent mode SCC.
  typedef struct scc_trans {
  	sccp_t	st_genscc;
! 	uint	st_cpres;	/* Preset CRC */
! 	uint	st_cmask;	/* Constant mask for CRC */
  } scc_trans_t;
  /* CPM interrupts.  There are nearly 32 interrupts generated by CPM
--- 335,479 ----
   * clock pins.
! #define PA_ENET_RXD	((unsigned short)0x0001)
! #define PA_ENET_TXD	((unsigned short)0x0002)
! #define PA_ENET_TCLK	((unsigned short)0x0200)
! #define PA_ENET_RCLK	((unsigned short)0x0800)
! #define PC_ENET_TENA	((unsigned short)0x0001)
! #define PC_ENET_CLSN	((unsigned short)0x0010)
! #define PC_ENET_RENA	((unsigned short)0x0020)
! #define SICR_ENET_MASK	((unsigned int)0x000000ff)
! #define SICR_ENET_CLKRT	((unsigned int)0x0000003d)
! #define SCCE_ENET_GRA	((unsigned short)0x0080)	/* Graceful stop complete */
! #define SCCE_ENET_TXE	((unsigned short)0x0010)	/* Transmit Error */
! #define SCCE_ENET_RXF	((unsigned short)0x0008)	/* Full frame received */
! #define SCCE_ENET_BSY	((unsigned short)0x0004)	/* All incoming buffers full */
! #define SCCE_ENET_TXB	((unsigned short)0x0002)	/* A buffer was transmitted */
! #define SCCE_ENET_RXB	((unsigned short)0x0001)	/* A buffer was received */
! #define SCC_PMSR_HBC	((unsigned short)0x8000)	/* Enable heartbeat */
! #define SCC_PMSR_FC	((unsigned short)0x4000)	/* Force collision */
! #define SCC_PMSR_RSH	((unsigned short)0x2000)	/* Receive short frames */
! #define SCC_PMSR_IAM	((unsigned short)0x1000)	/* Check individual hash */
! #define SCC_PMSR_ENCRC	((unsigned short)0x0800)	/* Ethernet CRC mode */
! #define SCC_PMSR_PRO	((unsigned short)0x0200)	/* Promiscuous mode */
! #define SCC_PMSR_BRO	((unsigned short)0x0100)	/* Catch broadcast pkts */
! #define SCC_PMSR_SBT	((unsigned short)0x0080)	/* Special backoff timer */
! #define SCC_PMSR_LPB	((unsigned short)0x0040)	/* Set Loopback mode */
! #define SCC_PMSR_SIP	((unsigned short)0x0020)	/* Sample Input Pins */
! #define SCC_PMSR_LCW	((unsigned short)0x0010)	/* Late collision window */
! #define SCC_PMSR_NIB22	((unsigned short)0x000a)	/* Start frame search */
! #define SCC_PMSR_FDE	((unsigned short)0x0001)	/* Full duplex enable */
! #define BD_ENET_RX_EMPTY	((unsigned short)0x8000)
! #define BD_ENET_RX_WRAP		((unsigned short)0x2000)
! #define BD_ENET_RX_INTR		((unsigned short)0x1000)
! #define BD_ENET_RX_LAST		((unsigned short)0x0800)
! #define BD_ENET_RX_FIRST	((unsigned short)0x0400)
! #define BD_ENET_RX_MISS		((unsigned short)0x0100)
! #define BD_ENET_RX_LG		((unsigned short)0x0020)
! #define BD_ENET_RX_NO		((unsigned short)0x0010)
! #define BD_ENET_RX_SH		((unsigned short)0x0008)
! #define BD_ENET_RX_CR		((unsigned short)0x0004)
! #define BD_ENET_RX_OV		((unsigned short)0x0002)
! #define BD_ENET_RX_CL		((unsigned short)0x0001)
! #define BD_ENET_RX_STATS	((unsigned short)0x013f)	/* All status bits */
! #define BD_ENET_TX_READY	((unsigned short)0x8000)
! #define BD_ENET_TX_PAD		((unsigned short)0x4000)
! #define BD_ENET_TX_WRAP		((unsigned short)0x2000)
! #define BD_ENET_TX_INTR		((unsigned short)0x1000)
! #define BD_ENET_TX_LAST		((unsigned short)0x0800)
! #define BD_ENET_TX_TC		((unsigned short)0x0400)
! #define BD_ENET_TX_DEF		((unsigned short)0x0200)
! #define BD_ENET_TX_HB		((unsigned short)0x0100)
! #define BD_ENET_TX_LC		((unsigned short)0x0080)
! #define BD_ENET_TX_RL		((unsigned short)0x0040)
! #define BD_ENET_TX_RCMASK	((unsigned short)0x003c)
! #define BD_ENET_TX_UN		((unsigned short)0x0002)
! #define BD_ENET_TX_CSL		((unsigned short)0x0001)
! #define BD_ENET_TX_STATS	((unsigned short)0x03ff)	/* All status bits */
  /* SCC as UART
  	sccp_t	scc_genscc;
! 	unsigned int	scc_res1;	/* Reserved */
! 	unsigned int	scc_res2;	/* Reserved */
! 	unsigned short	scc_maxidl;	/* Maximum idle chars */
! 	unsigned short	scc_idlc;	/* temp idle counter */
! 	unsigned short	scc_brkcr;	/* Break count register */
! 	unsigned short	scc_parec;	/* receive parity error counter */
! 	unsigned short	scc_frmec;	/* receive framing error counter */
! 	unsigned short	scc_nosec;	/* receive noise counter */
! 	unsigned short	scc_brkec;	/* receive break condition counter */
! 	unsigned short	scc_brkln;	/* last received break length */
! 	unsigned short	scc_uaddr1;	/* UART address character 1 */
! 	unsigned short	scc_uaddr2;	/* UART address character 2 */
! 	unsigned short	scc_rtemp;	/* Temp storage */
! 	unsigned short	scc_toseq;	/* Transmit out of sequence char */
! 	unsigned short	scc_char1;	/* control character 1 */
! 	unsigned short	scc_char2;	/* control character 2 */
! 	unsigned short	scc_char3;	/* control character 3 */
! 	unsigned short	scc_char4;	/* control character 4 */
! 	unsigned short	scc_char5;	/* control character 5 */
! 	unsigned short	scc_char6;	/* control character 6 */
! 	unsigned short	scc_char7;	/* control character 7 */
! 	unsigned short	scc_char8;	/* control character 8 */
! 	unsigned short	scc_rccm;	/* receive control character mask */
! 	unsigned short	scc_rccr;	/* receive control character register */
! 	unsigned short	scc_rlbc;	/* receive last break character */
  } scc_uart_t;
! #define UART_SCCM_GLR		((unsigned short)0x1000)
! #define UART_SCCM_GLT		((unsigned short)0x0800)
! #define UART_SCCM_AB		((unsigned short)0x0200)
! #define UART_SCCM_IDL		((unsigned short)0x0100)
! #define UART_SCCM_GRA		((unsigned short)0x0080)
! #define UART_SCCM_BRKE		((unsigned short)0x0040)
! #define UART_SCCM_BRKS		((unsigned short)0x0020)
! #define UART_SCCM_CCR		((unsigned short)0x0008)
! #define UART_SCCM_BSY		((unsigned short)0x0004)
! #define UART_SCCM_TX		((unsigned short)0x0002)
! #define UART_SCCM_RX		((unsigned short)0x0001)
! #define SCU_PMSR_FLC		((unsigned short)0x8000)
! #define SCU_PMSR_SL		((unsigned short)0x4000)
! #define SCU_PMSR_CL		((unsigned short)0x3000)
! #define SCU_PMSR_UM		((unsigned short)0x0c00)
! #define SCU_PMSR_FRZ		((unsigned short)0x0200)
! #define SCU_PMSR_RZS		((unsigned short)0x0100)
! #define SCU_PMSR_SYN		((unsigned short)0x0080)
! #define SCU_PMSR_DRT		((unsigned short)0x0040)
! #define SCU_PMSR_PEN		((unsigned short)0x0010)
! #define SCU_PMSR_RPM		((unsigned short)0x000c)
! #define SCU_PMSR_REVP		((unsigned short)0x0008)
! #define SCU_PMSR_TPM		((unsigned short)0x0003)
! #define SCU_PMSR_TEVP		((unsigned short)0x0003)
  	sccp_t	st_genscc;
! 	unsigned int	st_cpres;	/* Preset CRC */
! 	unsigned int	st_cmask;	/* Constant mask for CRC */
  } scc_trans_t;
*** 484,529 ****
   * priority and SCC1 == SCCa, etc...).
  #define CPMVEC_NR		32
! #define	CPMVEC_PIO_PC15		((ushort)0x1f)
! #define	CPMVEC_SCC1		((ushort)0x1e)
! #define	CPMVEC_SCC2		((ushort)0x1d)
! #define	CPMVEC_SCC3		((ushort)0x1c)
! #define	CPMVEC_SCC4		((ushort)0x1b)
! #define	CPMVEC_PIO_PC14		((ushort)0x1a)
! #define	CPMVEC_TIMER1		((ushort)0x19)
! #define	CPMVEC_PIO_PC13		((ushort)0x18)
! #define	CPMVEC_PIO_PC12		((ushort)0x17)
! #define	CPMVEC_SDMA_CB_ERR	((ushort)0x16)
! #define CPMVEC_IDMA1		((ushort)0x15)
! #define CPMVEC_IDMA2		((ushort)0x14)
! #define CPMVEC_TIMER2		((ushort)0x12)
! #define CPMVEC_RISCTIMER	((ushort)0x11)
! #define CPMVEC_I2C		((ushort)0x10)
! #define	CPMVEC_PIO_PC11		((ushort)0x0f)
! #define	CPMVEC_PIO_PC10		((ushort)0x0e)
! #define CPMVEC_TIMER3		((ushort)0x0c)
! #define	CPMVEC_PIO_PC9		((ushort)0x0b)
! #define	CPMVEC_PIO_PC8		((ushort)0x0a)
! #define	CPMVEC_PIO_PC7		((ushort)0x09)
! #define CPMVEC_TIMER4		((ushort)0x07)
! #define	CPMVEC_PIO_PC6		((ushort)0x06)
! #define	CPMVEC_SPI		((ushort)0x05)
! #define	CPMVEC_SMC1		((ushort)0x04)
! #define	CPMVEC_SMC2		((ushort)0x03)
! #define	CPMVEC_PIO_PC5		((ushort)0x02)
! #define	CPMVEC_PIO_PC4		((ushort)0x01)
! #define	CPMVEC_ERROR		((ushort)0x00)
  extern void cpm_install_handler(int vec, void (*handler)(void *), void *dev_id);
  /* CPM interrupt configuration vector.
! #define	CICR_SCD_SCC4		((uint)0x00c00000)	/* SCC4 @ SCCd */
! #define	CICR_SCC_SCC3		((uint)0x00200000)	/* SCC3 @ SCCc */
! #define	CICR_SCB_SCC2		((uint)0x00040000)	/* SCC2 @ SCCb */
! #define	CICR_SCA_SCC1		((uint)0x00000000)	/* SCC1 @ SCCa */
! #define CICR_IRL_MASK		((uint)0x0000e000)	/* Core interrrupt */
! #define CICR_HP_MASK		((uint)0x00001f00)	/* Hi-pri int. */
! #define CICR_IEN		((uint)0x00000080)	/* Int. enable */
! #define CICR_SPS		((uint)0x00000001)	/* SCC Spread */
  #endif /* __CPM_8XX__ */
--- 484,529 ----
! #define	CPMVEC_PIO_PC15		((unsigned short)0x1f)
! #define	CPMVEC_SCC1		((unsigned short)0x1e)
! #define	CPMVEC_SCC2		((unsigned short)0x1d)
! #define	CPMVEC_SCC3		((unsigned short)0x1c)
! #define	CPMVEC_SCC4		((unsigned short)0x1b)
! #define	CPMVEC_PIO_PC14		((unsigned short)0x1a)
! #define	CPMVEC_TIMER1		((unsigned short)0x19)
! #define	CPMVEC_PIO_PC13		((unsigned short)0x18)
! #define	CPMVEC_PIO_PC12		((unsigned short)0x17)
! #define	CPMVEC_SDMA_CB_ERR	((unsigned short)0x16)
! #define CPMVEC_IDMA1		((unsigned short)0x15)
! #define CPMVEC_IDMA2		((unsigned short)0x14)
! #define CPMVEC_TIMER2		((unsigned short)0x12)
! #define CPMVEC_RISCTIMER	((unsigned short)0x11)
! #define CPMVEC_I2C		((unsigned short)0x10)
! #define	CPMVEC_PIO_PC11		((unsigned short)0x0f)
! #define	CPMVEC_PIO_PC10		((unsigned short)0x0e)
! #define CPMVEC_TIMER3		((unsigned short)0x0c)
! #define	CPMVEC_PIO_PC9		((unsigned short)0x0b)
! #define	CPMVEC_PIO_PC8		((unsigned short)0x0a)
! #define	CPMVEC_PIO_PC7		((unsigned short)0x09)
! #define CPMVEC_TIMER4		((unsigned short)0x07)
! #define	CPMVEC_PIO_PC6		((unsigned short)0x06)
! #define	CPMVEC_SPI		((unsigned short)0x05)
! #define	CPMVEC_SMC1		((unsigned short)0x04)
! #define	CPMVEC_SMC2		((unsigned short)0x03)
! #define	CPMVEC_PIO_PC5		((unsigned short)0x02)
! #define	CPMVEC_PIO_PC4		((unsigned short)0x01)
! #define	CPMVEC_ERROR		((unsigned short)0x00)
! #define	CICR_SCD_SCC4		((unsigned int)0x00c00000)	/* SCC4 @ SCCd */
! #define	CICR_SCC_SCC3		((unsigned int)0x00200000)	/* SCC3 @ SCCc */
! #define	CICR_SCB_SCC2		((unsigned int)0x00040000)	/* SCC2 @ SCCb */
! #define	CICR_SCA_SCC1		((unsigned int)0x00000000)	/* SCC1 @ SCCa */
! #define CICR_IRL_MASK		((unsigned int)0x0000e000)	/* Core interrrupt */
! #define CICR_HP_MASK		((unsigned int)0x00001f00)	/* Hi-pri int. */
! #define CICR_IEN		((unsigned int)0x00000080)	/* Int. enable */
! #define CICR_SPS		((unsigned int)0x00000001)	/* SCC Spread */
diff -r -c -N rtems/c/src/lib/libbsp/powerpc/mbx8xx/startup/start.S rtems.new/c/src/lib/libbsp/powerpc/mbx8xx/startup/start.S
*** rtems/c/src/lib/libbsp/powerpc/mbx8xx/startup/start.S	Fri Apr  6 17:52:03 2001
--- rtems.new/c/src/lib/libbsp/powerpc/mbx8xx/startup/start.S	Tue Jun  5 13:58:55 2001
*** 242,247 ****
--- 242,249 ----
   * #define LOADED_BY_EPPCBUG
+ #define LOADED_BY_EPPCBUG
   * Initialization code
*** 275,281 ****
          /* Clear the bss section. */
          bl      bssclr
          nop
  	lis	r5,environ at ha
          la	r5,environ at l(r5)		/* environp */
          /* clear argc and argv */
--- 277,286 ----
          bl      bssclr
          nop
! #if defined(EARLY_CONSOLE) && defined(LOADED_BY_EPPCBUG)
! 	EXTERN_PROC (serial_init)
! 	bl	PROC (serial_init)
! #endif
diff -r -c -N rtems/c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c rtems.new/c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c
*** rtems/c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c	Mon May 21 12:21:33 2001
--- rtems.new/c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c	Tue May 29 14:54:50 2001
*** 898,903 ****
--- 898,904 ----
    if ( (minor < SMC1_MINOR) || (minor > SMC2_MINOR) )
      return;
+   m8xx.sdcr = 0x01;                 /* as per section 16.10.2.1 MPC821UM/AD */
    /* Get the simode clock source bit values for 9600 bps */
    brg = m8xx_get_brg_clk(9600);
