no more errno after device read?
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Tue Jun 12 13:21:02 UTC 2001
Hi,
I am currently fussing around with PPP-related error handling under
rtems-4.5.0 (the released sources, not a snapshot). I am suprised to
see, that "errno" is no longer set, when an error occures in the
device drivers read function, although it was set under rtems-4.0.0.
I know that there were significant changes due to IMFS
infrastructure. Under rtems-4.0.0, the device driver returned an
error code to __rtems_read (file: libio.c), and there it was
translated into errno using rtems_libio_errno().
Under rtems-4.5.0, the corresponding function device_read (file:
deviceio.c) returns a -1 if an error was reported, but does not set
errno.
According to the Linux man pages, "read()" should set errno if an
error occured, so I think it is a bit of an illegal shortcut to drop
any error reason code in device_read().
Has this bug already been discussed? (or even fixed?)
bye,
Thomas.
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-systems.de/pgp_key.htm
