libstdc++-v3 and threading
Joel Sherrill
joel at OARcorp.com
Fri Jun 15 21:43:53 UTC 2001
I think you now have to --enable-threads=rtems and there is a missing
support
function. This is the configure line I am using:
../gcc-3.0-20010614/configure --target=${1}-rtems \
--with-gnu-as --with-gnu-ld --with-newlib --verbose \
--enable-threads=rtems --prefix=/opt/rtems && make
I do have a small patch to get the missing RTEMS patch bits in place.
I have attached it. At this point, the targets that I know have
RTEMS specific target problems are:
i386-rtems (uses deprecated CPU cflags for multilib variants)
*-rtems (libstdc++-v3 .. some problem produces the error
message below. This can be duplicated on at least the sparc.)
Other targets have problems (h8300, m68k-elf, powerpc-eabi,
sh-coff) that are generic non-rtems problems.
This is the error I am getting on all RTEMS builds (that don't have
a core dump before there :):
In file included from
../../../../gcc-3.0-20010614/libstdc++-v3/include/bits/stl_alloc.h:38,
from
../../../../gcc-3.0-20010614/libstdc++-v3/include/bits/std_memory.h:21,
from
../../../../gcc-3.0-20010614/libstdc++-v3/include/bits/std_string.h:43,
from
../../../../gcc-3.0-20010614/libstdc++-v3/src/stdexcept.cc:34:
../../../../gcc-3.0-20010614/libstdc++-v3/include/bits/stl_threads.h: In
member function `void std::_STL_mutex_lock::_M_initialize()':
../../../../gcc-3.0-20010614/libstdc++-v3/include/bits/stl_threads.h:327:
`__gthread_active_p'
undeclared (first use this function)
(Each undeclared identifier is reported only once for each function it
appears in.)
make[3]: *** [stdexcept.lo] Error 1
Does anyone have any ideas about this, the multilib problem?
--joel
Type: application/gzip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010615/2d2fd248/attachment.bin>
