Failed dependencies error when install i960-rtems-gdb-5.0-3.i386.rpm
Sanford Liao sliao at runtop.com.tw
Mon Jun 18 09:08:29 UTC 2001
Hi,
I'm installing the i960-rtems-gdb-5.0 on Redhat Linux 7.0. The following is the result:
[root]# rpm -i  i960-rtems-gdb-5.0-3.i386.rpm
error: failed dependencies:
        libncurses.so.4 is nedded by i960-rtems-gdb-5.0-3
I have installed rtems-base-binutils-2.11-3.i386.rpm, i960-rtems-binutils-2.11-3.i386.rpm,
rtems-base-gcc-gcc2.95.2newlib1.9.0-2.i386.rpm, i960-rtems-gcc-gcc2.95.2newlib1.9.0-2.i386.rpm,
and rtems-base-gdb-5.0-3.i386.rpm.
Where can I find libncurses.so.4 ?
-sanford
URL: <http://lists.rtems.org/pipermail/users/attachments/20010618/20a28c00/attachment.html>
