Failed dependencies error when install i960-rtems-gdb-5.0-3.i 386.rpm
Nick.SIMON at syntegra.com Nick.SIMON at syntegra.com
Mon Jun 18 09:39:45 UTC 2001
On my Red Hat 6.1, libncurses.so.4 comes from compat-libs-5.2-2.
Regards,
-- Nick Simon
-----Original Message-----
Sent: 18 June 2001 10:08
To: rtems-users
Subject: Failed dependencies error when install
i960-rtems-gdb-5.0-3.i386.rpm
Hi,
I'm installing the i960-rtems-gdb-5.0 on Redhat Linux 7.0. The following is
the result:
[root]# rpm -i  i960-rtems-gdb-5.0-3.i386.rpm
error: failed dependencies:
        libncurses.so.4 is nedded by i960-rtems-gdb-5.0-3
I have installed rtems-base-binutils-2.11-3.i386.rpm, i960-rtems-binutils-2.
11-3.i386.rpm,
rtems-base-gcc-gcc2.95.2newlib1.9.0-2.i386.rpm,
i960-rtems-gcc-gcc2.95.2newlib1.9.0-2.i386.rpm,
and rtems-base-gdb-5.0-3.i386.rpm.
Where can I find libncurses.so.4 ?
-sanford
This email may contain information which is privileged or confidential. If you are not the intended recipient of this email, please notify the sender immediately and delete it without reading, copying, storing, forwarding or disclosing its contents to any other person
Thank you
Check us out at http://www.syntegra.com
