Very strange bug
Pascal Chevochot Pascal.Chevochot at irisa.fr
Tue Jun 19 07:11:35 UTC 2001
Hello,
>>>>> "Joel" == Joel Sherrill <joel at OARcorp.com> writes:
    Joel> Pascal Chevochot wrote:
    >> Hello,
    >> Below, you can find a short program. With rtems 4.5.0/bsp586, it
    >> works
    >> fine. But if I uncomment line `printf("2\n");', then this programm
    >> badly crashes !!! Now, if I replace `printf' by `puts', it works !!!
    >> Could someone make this test on another bsp586 ?
    Joel> I ran it on the sparc/erc32 BSP and it worked fine.  It produced this
    Joel> output:
    Joel> 1
    Joel> id
    Joel> 2
    Joel> wakeup
    Joel> And then went into a tight look in mainThread.  What else does it do?
It is the correct result.
    Joel> I would normally suspect a stack problem.  I would suspect that printf
    Joel> takes more
    Joel> memory than puts.  But that is just a guess.
If I increase the stack size, there is still the problem.
Pascal.
Irisa - Solidor - HADES     | E-mail : Pascal.Chevochot at irisa.fr
Bureau E-302 (niv rouge)    | Phone  : [+33|0]2 99 84 25 02
Campus de Beaulieu          | Fax    : [+33|0]2 99 84 71 71
35042 Rennes Cedex, France  | http://www.irisa.fr/solidor/work/hades
