i386ex: hangups during initialization
Jürgen Zeller
juergen.zeller at argovision.de
Tue Jun 19 12:13:33 UTC 2001
hello everybody,
I'm doing my first steps with RTEMS 4.5 and I have big
problems building RTEMS for i386ex.
During the initialization my system hangs up, so I tried to
find out, what the reason is. I've inserted many 'printk's'
in the rtems_executive_early function to see, how much code
gets processed.
But after a while I found out that the error is not constant at the
same time or function, it depends for example how much printk's I issue!
But in following illogical manner:
so more printk's I use so more code I get processed!
I've checked my register settings, my linkcmds and my start.S often
but I can't find the error.
Has anybody an idea what could go wrong in my application?
Could it be a Hardware problem?
I use a bootloader for downloading, could this be the reason? And why?
I have no experience with RTEMS and I would be obliged for every tip I
get.
RAM 0x00000000 .. 0x0003ffff
Flash 0x00080000 .. 0x000fffff
here my printk - results
rtems_initialize_executive_early: 001
rtems_initialize_executive_early: 002
rtems_initialize_executive_early: 003
rtems_initialize_executive_early: 004
rtems_initialize_executive_early: 005
rtems_initialize_executive_early: 006
rtems_initialize_executive_early: 007
rtems_initialize_executive_early: 008
rtems_initialize_executive_early: 009
rtems_initialize_executive_early: 010
rtems_initialize_executive_early: 011
rtems_initialize_executive_early: 012
rtems_initialize_executive_early: 013
rtems_initialize_executive_early: 014
Exception 13 caught at PC 87F66 by thread -1912602608
Processor execution context at time of the fault was :
EAX = B624 EBX = 46 ECX = B620 EDX = FFFFFFFF
ESI = 0 EDI = 200144 EBP = B5CC ESP = B5B0
Error code pushed by processor itself (if not 0) = 0
************ FAULTY THREAD WILL BE DELETED **************
thanks a lot for your help!
Jürgen Zeller
Entwicklung Software
TVI Lederer GmbH & Co KG
Industriestr. 4, 93161 Sinzing
Tel. 0941-3073761 - Fax 0941-3073737
