rtems build fails for 20010525 ss w/o networking
Joel Sherrill joel at OARcorp.com
Tue Jun 19 19:37:23 UTC 2001
Jerry Needell wrote:
> If I try to build the 20010525 snapshot without networking enabled, it
> fails complaining that sys/socket.h is not found. This happens trying to
> compile telnetd.c. Has anyone else seen this, or does eveyone use enable
> networking? It builds fine with networking enabled.
Yep. Just a one snapshot mistake because of a merged telnetd.  The next
snapshot should
have this fixed.
> I am using binutils21.1, newlib1.9.0 and bot gcc 2.95.2 and gcc 3.0
> (20010614)
> BTW with gcc 3.0 the build faile if I enable POSIX - proble with
> arguments to va-arg. I'm
> still expeimenting with this. It builds w/o POSIX.
<growl>  I have not managed to get enough *-rtems tools built with 3.0
to even think
about trying to compile RTEMS.  Can you post the output to the
rtems-users mailing
list under a separate header?  We may have to report that to the
gcc-bugs list.
> - Jerry
