Network Write Delay using PPPD
Mike Siers
mikes at poliac.com
Wed Jun 20 22:24:00 UTC 2001
Hi,
I am using the i386/pc586 BSP with the latest snapshot. My code
is using the standard pppd task to establish a network connection.
The ppp connection gets established and I can create a socket and
connect to my server test application.
The RTEMS client code will write a block of data every time it
receives some data over the socket. The problem that I am seeing
is that the client write seems to be getting delayed. And the
delay keeps getting longer after each successive write. After four
writes, the delay is about 90 seconds! I have turned off the pppd
compression options.
I added some debug statements to the pppd code. Basically it looks
like the pppoutput function is getting called immediately but the
modem_sendpacket function call gets delayed.
Has anyone seen this problem before? Any thoughts or suggestions
would be greatly appreciated.
Thanks
Mike Siers
