BLOWN STACK!!!
Thu Jun 21 18:04:13 UTC 2001
Alejandro Villanueva wrote:
> Hi you all,
> Anybody knows how can I increase stack size under RTEMS 4.0.0 ?
> I've got the following error:
> BLOWN STACK!!! Offending task(0xaa3f84): id=0x0x010003; name=0x001523ef
>   stack covers range 0x0029b15c - 0x0029c15b (4096 bytes)
>   Damaged pattern begins at 0x0029b164 and is 16 bytes long
> It should be easy, so I keep waiting for your prompt answer.
Pass a larger number as the stack size on the task create for
the offending task.  It appears to be the 3rd task created
counting the Init task in your application task as the first one.
> Thanks,
> Alejandro.
> 190921 at cepsz.unizar.es
