i386-rtems-gcc - cannot find ld
Thomas Bocek
draft at icu.unizh.ch
Fri Jun 22 22:57:48 UTC 2001
Hi
I have a problem with compiling a sample file:
the command:
"minimore:/home/draft/kernel# i386-rtems-gcc -v dumpcopy.c"
returns me:
"Reading specs from /opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/specs
gcc version 2.95.2 19991024 (release)
/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/cpp -lang-c -v -D__GNUC__=2
-D__GNUC_MINOR__=95 -Di386 -Drtems -D__rtems__ -D__i386__ -D__rtems__
-D__rtems__ -D__i386 -D__rtems -Asystem(rtems) -Acpu(i386) -Amachine(i386)
dumpcopy.c /tmp/ccvoBFMS.i
GNU CPP version 2.95.2 19991024 (release) (i386 RTEMS with ELF)
#include "..." search starts here:
#include <...> search starts here:
/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/include
/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/../../../../i386-rtems/include
End of search list.
The following default directories have been omitted from the search path:
/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/../../../../include/g++-3
/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/../../../../i386-rtems/sys-include
End of omitted list.
/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/cc1 /tmp/ccvoBFMS.i -quiet
-dumpbase dumpcopy.c -version -o /tmp/ccWpI82K.s
GNU C version 2.95.2 19991024 (release) (i386-rtems) compiled by GNU C
version 2.7.2.3.
as -V -Qy -o /tmp/ccBG30FP.o /tmp/ccWpI82K.s
GNU assembler version 2.11.90.0.7 (i386-linux) using BFD version 2.11.90.0.7
/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/collect2 -V -Qy
/opt/rtems/i386-rtems/lib/crt0.o
/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/crti.o
/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/crtbegin.o
-L/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2 -L/opt/rtems/i386-rtems/lib
/tmp/ccBG30FP.o -lgcc -lc -lgcc
/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/crtend.o
/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/crtn.o
collect2: cannot find `ld'"
where is the problem? (ld form the command prompt works)
Thomas
