i386-rtems-gcc - cannot find ld
Mon Jun 25 12:24:11 UTC 2001
Thomas Bocek wrote:
> Hi all
> > is i386-rtems-as or i386-rtems-ld in your PATH?  You have to use the
> > binutils for the target.
> thanks a lot, the deb and rpm packages seems to be broken, i had to download
> the source. version 4.5.0 (corrupt file).
Whatr exactly did you do and what happened?  No one else has reported
this.
> I could manage to compile the test
> .c file. and here is my 2nd problem: after a make all in my directory this
> message was on my screen:
> /opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/ld:../../../../../../i386ex/lib/linkcmds:115:
> parse error
> collect2: ld returned 1 exit status
> hmm whats wrong?
What does line 115 look like?  My copy -- checked out of
CVS has a 5 where an = should be on line 115.  Weird.
> Regards Thomas
