Cygwin host failure during configure...
Silverio Diquigiovanni silverio.di at qem.it
Wed Jun 27 09:50:51 UTC 2001
Ok, I agree with you...
I think the problem is because the configure don't found the cc.exe...
In fact I found only the gcc.exe. In past version of Cygwin I remember
that cc.exe exist, but in this it isn't available.
At this point I don't know the valid soluction !
Have someone a suggestion ?
----- Original Message -----
From: "Krishna, Buska (IE10)" <Krishna.Buska at honeywell.com>
To: "Silverio Diquigiovanni" <silverio.di at qem.it>
Sent: Wednesday, June 27, 2001 11:08 AM
Subject: RE: Cygwin host failure during configure...
> Hi Silverio,
> I too am trying the same thing. I too am getting some problems.
> Let's do one thing, we both try to build it ok?
> reply...Immediately..
> Krishna
> > -----Original Message-----
> > From: Silverio Diquigiovanni [SMTP:silverio.di at qem.it]
> > Sent: Wednesday, June 27, 2001 2:22 PM
> > To: rtems-users at oarcorp.com
> > Subject: Cygwin host failure during configure...
> > Hi to all,
> > I have found a problem during configure phase of RTEMS in Cygwin
> > environment.
> > I have downloaded and installed last version of Cygwin environment and I
> > have:
> >      automake --version <cr>
> >      autoconf --version <cr>
> >      perl --version <cr>
> >      make --version <cr>
> >      automake = 1.4
> >      autoconf = 2.13
> >      perl = 5.6.1
> >      make = 3.79.1
> > I have downloaded and installed 4.5.0 RPM tool-chain for Cygwin with :
> >      rpm -i --nodeps --ignoreos
rtems-base-binutils-2.9.5.0.24-1.i386.rpm
> > <cr>
> > rtems-base-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm <cr>
> >      rpm -i --nodeps --ignoreos rtems-base-gdb-4.18-4.i386.rpm <cr>
> >      rpm -i --nodeps --ignoreos sh-rtems-binutils-2.9.5.0.24-1.i386.rpm
> > <cr>
> > sh-rtems-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm
> > <cr>
> >      rpm -i --nodeps --ignoreos sh-rtems-gdb-4.18-4.i386.rpm <cr>
> > My RTEMS source code is :
> >      rtems-4.5.0.tgz
> > I have modified the .bashrc to:
> >     # RTEMS environment
> >     # Visibility to egcs binary for sh processors
> >     export PATH=$PATH:/opt/rtems/bin
> > This is my directory tree:
> > /home/SILVERIO_DIQUIGIOVANNI/build/sh-rtems-01/
> > /home/SILVERIO_DIQUIGIOVANNI/source/rtems-4.5.0/
> > Then from ..../build/sh-rtems-01/ I have launched the configurator:
> > ../../source/rtems-4.5.0/configure \
> >     --target=sh-rtems \
> >     --prefix=/home/SILVERIO_DIQUIGIOVANNI/rtems-4.5.0/sh-rtems-01/ \
> >     --disable-multiprocessing \
> >     --disable-posix \
> >     --disable-itron \
> >     --disable-networking \
> >     --disable-rdbg
> >     --disable-cxx \
> >     --disable-tests
> > after few configure steps I obtain :
> > < start snip from output >
> > /../../../source/rtems-4.5.0/tools/build
> > loading cache ../.././config.cache
> > checking for RTEMS Version... 4.5.0
> > checking host system type... i386-pc-cygwin32
> > checking for a BSD compatible install... (cached) /usr/bin/install -c
> > checking whether build environment is sane... yes
> > checking whether make sets ${MAKE}... (cached) yes
> > checking for working aclocal... found
> > checking for working autoconf... found
> > checking for working automake... found
> > checking for working autoheader... found
> > checking for working makeinfo... found
> > checking whether to enable maintainer-specific portions of Makefiles...
no
> > checking for Cygwin environment... no
> > checking for mingw32 environment... no
> > checking for executable suffix... configure: error: installation or
> > configuration problem: compiler cannot create executables.
> > configure: error: ../../../../source/rtems-4.5.0/tools/build/configure
> > failed for tools/build
> > < end snip from output >
> > If I launch gcc --version I obtain 2.95.3-5
> > Someone has some suggestion obout my problem ?
> > Thank you in advance
> > Regards,
