Cygwin host failure during configure...
Silverio Diquigiovanni silverio.di at qem.it
Wed Jun 27 10:02:02 UTC 2001
I have tried to copy /bin/gcc.exe in /bin/cc.exe and now
configure seem run fine. I don't know if this is a correct
operation....
Regards,
----- Original Message -----
From: "Silverio Diquigiovanni" <silverio.di at qem.it>
To: <rtems-users at oarcorp.com>; "Krishna, Buska (IE10)"
<Krishna.Buska at honeywell.com>
Sent: Wednesday, June 27, 2001 11:50 AM
Subject: Re: Cygwin host failure during configure...
> Ok, I agree with you...
> I think the problem is because the configure don't found the cc.exe...
> In fact I found only the gcc.exe. In past version of Cygwin I remember
> that cc.exe exist, but in this it isn't available.
> At this point I don't know the valid soluction !
> Have someone a suggestion ?
> From: "Krishna, Buska (IE10)" <Krishna.Buska at honeywell.com>
> To: "Silverio Diquigiovanni" <silverio.di at qem.it>
> Sent: Wednesday, June 27, 2001 11:08 AM
> Subject: RE: Cygwin host failure during configure...
> > Hi Silverio,
> > I too am trying the same thing. I too am getting some problems.
> > Let's do one thing, we both try to build it ok?
> > reply...Immediately..
> > Krishna
> > > -----Original Message-----
> > > From: Silverio Diquigiovanni [SMTP:silverio.di at qem.it]
> > > Sent: Wednesday, June 27, 2001 2:22 PM
> > > To: rtems-users at oarcorp.com
> > > Subject: Cygwin host failure during configure...
> > > Hi to all,
> > > I have found a problem during configure phase of RTEMS in Cygwin
> > > environment.
> > > I have downloaded and installed last version of Cygwin environment and
I
> > > have:
> > >      automake --version <cr>
> > >      autoconf --version <cr>
> > >      perl --version <cr>
> > >      make --version <cr>
> > >      automake = 1.4
> > >      autoconf = 2.13
> > >      perl = 5.6.1
> > >      make = 3.79.1
> > > I have downloaded and installed 4.5.0 RPM tool-chain for Cygwin with :
> > >      rpm -i --nodeps --ignoreos
> rtems-base-binutils-2.9.5.0.24-1.i386.rpm
> > > <cr>
> > > rtems-base-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm <cr>
> > >      rpm -i --nodeps --ignoreos rtems-base-gdb-4.18-4.i386.rpm <cr>
sh-rtems-binutils-2.9.5.0.24-1.i386.rpm
> > > <cr>
> > > sh-rtems-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm
> > > <cr>
> > >      rpm -i --nodeps --ignoreos sh-rtems-gdb-4.18-4.i386.rpm <cr>
> > > My RTEMS source code is :
> > >      rtems-4.5.0.tgz
> > > I have modified the .bashrc to:
> > >     # RTEMS environment
> > >     # Visibility to egcs binary for sh processors
> > >     export PATH=$PATH:/opt/rtems/bin
> > > This is my directory tree:
> > > /home/SILVERIO_DIQUIGIOVANNI/build/sh-rtems-01/
> > > /home/SILVERIO_DIQUIGIOVANNI/source/rtems-4.5.0/
> > > Then from ..../build/sh-rtems-01/ I have launched the configurator:
> > > ../../source/rtems-4.5.0/configure \
> > >     --target=sh-rtems \
> > >     --prefix=/home/SILVERIO_DIQUIGIOVANNI/rtems-4.5.0/sh-rtems-01/ \
> > >     --disable-multiprocessing \
> > >     --disable-posix \
> > >     --disable-itron \
> > >     --disable-networking \
> > >     --disable-rdbg
> > >     --disable-cxx \
> > >     --disable-tests
> > > after few configure steps I obtain :
> > > < start snip from output >
> > > /../../../source/rtems-4.5.0/tools/build
> > > loading cache ../.././config.cache
> > > checking for RTEMS Version... 4.5.0
> > > checking host system type... i386-pc-cygwin32
> > > checking for a BSD compatible install... (cached) /usr/bin/install -c
> > > checking whether build environment is sane... yes
> > > checking whether make sets ${MAKE}... (cached) yes
> > > checking for working aclocal... found
> > > checking for working autoconf... found
> > > checking for working automake... found
> > > checking for working autoheader... found
> > > checking for working makeinfo... found
> > > checking whether to enable maintainer-specific portions of
Makefiles...
> no
> > > checking for Cygwin environment... no
> > > checking for mingw32 environment... no
> > > checking for executable suffix... configure: error: installation or
> > > configuration problem: compiler cannot create executables.
> > > configure: error: ../../../../source/rtems-4.5.0/tools/build/configure
> > > failed for tools/build
> > > < end snip from output >
> > > If I launch gcc --version I obtain 2.95.3-5
> > > Someone has some suggestion obout my problem ?
> > > Thank you in advance
> > > Regards,
