Network Write Delay using PPPD
Mike Siers mikes at poliac.com
Wed Jun 27 16:27:33 UTC 2001
Hi All,
Just wanted to post that I have fixed the problems that I was
having with pppd on the i386/pc586 BSP.  Below is a list of
requirements for pppd to work correctly.
  1) must have task driven serial I/O
     (I will post my i386 BSP changes to my other email about
     task driven serial driver for the i386).
  2) application tasks must have pre-empt mode (RTEMS_PREEMPT)
  3) application tasks must have lower priority than the
     termios tasks (i.e. priority value greater than 10)
Good Luck
Mike Siers
-----Original Message-----
Sent: Wednesday, June 20, 2001 5:24 PM
To: rtems-users at oarcorp.com
Subject: Network Write Delay using PPPD
Hi,
I am using the i386/pc586 BSP with the latest snapshot.  My code
is using the standard pppd task to establish a network connection.
The ppp connection gets established and I can create a socket and
connect to my server test application.
The RTEMS client code will write a block of data every time it
receives some data over the socket.  The problem that I am seeing
is that the client write seems to be getting delayed.  And the
delay keeps getting longer after each successive write.  After four
writes, the delay is about 90 seconds!  I have turned off the pppd
compression options.
I added some debug statements to the pppd code.  Basically it looks
like the pppoutput function is getting called immediately but the
modem_sendpacket function call gets delayed.
Has anyone seen this problem before?  Any thoughts or suggestions
would be greatly appreciated.
Thanks
Mike Siers
