i386ex: hangups during initialization
Angelo Fraietta angelo at hunterlink.net.au
Wed Jun 20 22:12:01 UTC 2001
The fault did not occur when I had the CONFIGURE_MICROSECONDS_PER_TICK set to
5000 even before the soft float was fixed, i.e. the fault only occurred with me
when it was set to 1000.  When the toolset was upgraded, I was able to set it to
1000 without crashing. I doubt that it had anything to do with an fp instruction
Joel Sherrill wrote:
> Angelo Fraietta wrote:
> > I had a similar bug a while ago. I set
> > #define CONFIGURE_MICROSECONDS_PER_TICK 1000 /* 1 ms */
> > to 5000 when I ran it on the 386 machine. After the soft float problem was
> > fixed, I set it back to 1000, however, I was only running three tasks.
> I could be wrong but I have to wonder what instruction is at the
> address reported in the exception and what exception 13 is.  Is
> this happening on an FP instruction?
> --joel
> > Jürgen Zeller wrote:
> > > hello everybody,
> > > I'm doing my first steps with RTEMS 4.5 and I have big
> > > problems building RTEMS for i386ex.
> > > During the initialization my system hangs up, so I tried to
> > > find out, what the reason is. I've inserted many 'printk's'
> > > in the rtems_executive_early function to see, how much code
> > > gets processed.
> > > But after a while I found out that the error is not constant at the
> > > same time or function, it depends for example how much printk's I issue!
> > > But in following illogical manner:
> > >  so more printk's I use so more code I get processed!
> > > I've checked my register settings, my linkcmds and my start.S often
> > > but I can't find the error.
> > > Has anybody an idea what could go wrong in my application?
> > > Could it be a Hardware problem?
> > > I use a bootloader for downloading, could this be the reason? And why?
> > > I have no experience with RTEMS and I would be obliged for every tip I
> > > get.
> > > RAM     0x00000000 .. 0x0003ffff
> > > Flash   0x00080000 .. 0x000fffff
> > > here my printk - results
> > >  rtems_initialize_executive_early: 001
> > >  rtems_initialize_executive_early: 002
> > >  rtems_initialize_executive_early: 003
> > >  rtems_initialize_executive_early: 004
> > >  rtems_initialize_executive_early: 005
> > >  rtems_initialize_executive_early: 006
> > >  rtems_initialize_executive_early: 007
> > >  rtems_initialize_executive_early: 008
> > >  rtems_initialize_executive_early: 009
> > >  rtems_initialize_executive_early: 010
> > >  rtems_initialize_executive_early: 011
> > >  rtems_initialize_executive_early: 012
> > >  rtems_initialize_executive_early: 013
> > >  rtems_initialize_executive_early: 014
> > > Exception 13 caught at PC 87F66 by thread -1912602608
> > > Processor execution context at time of the fault was  :
> > >  EAX = B624     EBX = 46        ECX = B620      EDX = FFFFFFFF
> > >  ESI = 0        EDI = 200144    EBP = B5CC      ESP = B5B0
> > > Error code pushed by processor itself (if not 0) = 0
> > >  ************ FAULTY THREAD WILL BE DELETED **************
> > > thanks a lot for your help!
> > >  Jürgen Zeller
> > >  Entwicklung Software
> > >  TVI Lederer GmbH & Co KG
> > >  Industriestr. 4, 93161 Sinzing
> > >  Tel. 0941-3073761 - Fax 0941-3073737
> > Angelo Fraietta
> > PO Box 859
> > Hamilton NSW 2303
> > Home Page
> > http://users.hunterlink.net.au/~maaaf/
> > There are those who seek knowledge for the sake of knowledge - that is
> > CURIOSITY
> > There are those who seek knowledge to be known by others - that is VANITY
> > There are those who seek knowledge in order to serve - that is LOVE
> >     Bernard of Clairvaux (1090 - 1153)
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>    Support Available             (256) 722-9985
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
