BLOWN STACK!!!
Alejandro Villanueva
190921 at cepsz.unizar.es
Thu Jun 21 16:58:42 UTC 2001
Thanks Joel, but I'm using GNAT, so I don't create my tasks explicitly and have
no idea on how to do it.
Could you help me, please?
Thanks a lot.
Alejandro.
On Thu, 21 Jun 2001, Joel Sherrill wrote:
> Alejandro Villanueva wrote:
> > Hi you all,
> > Anybody knows how can I increase stack size under RTEMS 4.0.0 ?
> > I've got the following error:
> > BLOWN STACK!!! Offending task(0xaa3f84): id=0x0x010003; name=0x001523ef
> > stack covers range 0x0029b15c - 0x0029c15b (4096 bytes)
> > Damaged pattern begins at 0x0029b164 and is 16 bytes long
> > It should be easy, so I keep waiting for your prompt answer.
> Pass a larger number as the stack size on the task create for
> the offending task. It appears to be the 3rd task created
> counting the Init task in your application task as the first one.
> > Thanks,
> > Alejandro.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
¿Quieres Cobrar por Navegar en Internet?
Visita: http://www.navegana.com/dinero/flintstone.html
