Network Write Delay using PPPD
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Sat Jun 23 17:42:35 UTC 2001
Hello Mike,
I just had another thought concerning your PPP problem: What kind of
serial driver do you use? The serial device driver used for PPP
connections MUST (!) use the new "task-driven" termios interface, and
currently only few BSPs (if any) support this model. So check the
device driver, if it uses termios polled or interrupt-driven mode,
problems are to be expected...
Bye,
Thomas.
> Hi,
> I am using the i386/pc586 BSP with the latest snapshot. My code
> is using the standard pppd task to establish a network connection.
> The ppp connection gets established and I can create a socket and
> connect to my server test application.
> The RTEMS client code will write a block of data every time it
> receives some data over the socket. The problem that I am seeing
> is that the client write seems to be getting delayed. And the
> delay keeps getting longer after each successive write. After four
> writes, the delay is about 90 seconds! I have turned off the pppd
> compression options.
> I added some debug statements to the pppd code. Basically it looks
> like the pppoutput function is getting called immediately but the
> modem_sendpacket function call gets delayed.
> Has anyone seen this problem before? Any thoughts or suggestions
> would be greatly appreciated.
> Thanks
> Mike Siers
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-systems.de/pgp_key.htm
