i386-rtems-gcc - cannot find ld
Thomas Bocek
draft at icu.unizh.ch
Sun Jun 24 22:46:31 UTC 2001
Hi all
> is i386-rtems-as or i386-rtems-ld in your PATH? You have to use the
> binutils for the target.
thanks a lot, the deb and rpm packages seems to be broken, i had to download
the source. version 4.5.0 (corrupt file). I could manage to compile the test
.c file. and here is my 2nd problem: after a make all in my directory this
message was on my screen:
/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/ld:../../../../../../i386ex/lib/linkcmds:115:
parse error
collect2: ld returned 1 exit status
hmm whats wrong?
Regards Thomas
