Cygwin host failure during configure...
Correo Fernando-ruiz (E-mail)
correo at fernando-ruiz.com
Wed Jun 27 20:03:38 UTC 2001
Only a bref explanation about symlink in cygwin.
> -----Mensaje original-----
> De: corsepiu [mailto:corsepiu]En nombre de Ralf Corsepius
> Enviado el: miercoles, 27 de junio de 2001 14:46
> Para: Silverio Diquigiovanni
> CC: rtems-users at oarcorp.com
> Asunto: Re: Cygwin host failure during configure...
> Silverio Diquigiovanni wrote:
> > Ralf, sorry for my ignorance about...
> > symlink is a program ?
> <*g*> You're not a Unix user? </*g*>
> symlink == symbolic link
> > In cygwin I don't have fount it...
> The program to install links normally is called "ln", installing
> symbolic links normally is performed by "ln -s".
> I am not sure if Cygwin has it but, I have been told cygwin so.
YES.
the cygwin symlink file is a small size file with attributtes hidden, system
and readonly contains some like this
!<symlink>rtems-ss-20010326
For a hard link the solution is very easy.
ln==cp (In Cygwin of course...)
ln makes a copy of source in the target.
Only with a symbolic link the small file is created.
> > Please write clear how to I must create a link between
> gcc.exe to cc.exe
> ln -s <path-to-gcc>/gcc.exe <somepath-in-$PATH>/cc.exe
> e.g.
> ln -s /bin/gcc.exe /bin/cc.exe
> [I don't know whether the .exe suffix is necessary under Cygwin.]
If you want execute the programs outside bash env. of course.
I can compile the programs (vi, rm, ln, etc) in the msdos command line.
> Ralf
