Task Driven Serial Driver for i386
Mike Siers mikes at poliac.com
Wed Jun 27 20:16:42 UTC 2001
Hi All,
Attached to this e-mail is a patch file that will add the
ability to use task driven serial I/O in the i386 BSP.  The
patch file can be applied to the 20010525 snapshot with the
following commands:
  cd c/src/lib/libbsp/i386/shared/comm
  cat comm.diff | patch -p1
This patch leaves the default I/O mode to be IRQ.  If you
want to use task I/O mode, then the tty_drv.c file needs
to be modified.  Basically, all you need to change is the
data values of the termios callbacks structure.  This callback
structure is used in the tty1_open and tty2_open functions.
The values you need to set are commented out in the source
code.
Please try it out.  I would like to get this patch merged
into the RTEMS source tree.
Good Luck
Mike Siers
-----Original Message-----
Sent: Monday, June 25, 2001 11:15 AM
To: rtems-users at OARcorp.com
Subject: Task Driven Serial Driver for i386
Hi,
I am looking at adding support for task driven serial I/O to
the i386 BSP.  Has anyone already made these changes?  If so
are they available for me to use?  I am using the lastest
RTEMS snapshot.
Mike Siers
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010627/a32332ef/attachment-0001.obj>
