RTEMS Build Problems on OpenBSD
James Housley jim at thehousleys.net
Mon Mar 5 15:03:11 UTC 2001
Mike Siers wrote:
> Hi,
> I am trying to build the RTEMS software on an OpenBSD 2.7 system.  I am
> using the following versions of the build tools:
>   gmake    3.78.1
>   autoconf 2.13
>   automake 1.4
> I downloaded all the files from ftp://oarcorp.com/pub/rtems/releases/4.5.0.
> I successfully built gcc, binutils, and newlib following the directions
> in the "Getting Started" document.  But when I try and build RTEMS itself,
> it does not work.  Has anyone successfully used OpenBSD/FreeBSD/NetBSD for
> a development platform?  Should I use the latest snapshot version instead
> of this released version?  If I switch to the latest snapshot version, do I
> need to use different versions of the build tools?
> The following lines are the last few lines that I am seeing when I try to
> build RTEMS.  Any ideas or thoughts would be appreciated.
Yes I have, but you will need a newer version.  Try one of the latest
snapshots, ftp:://ftp.oarcorp.com/pub/rtems/snapshots/rtems/ .  You
might also want to look at http://www.FreeBSD.org/ports/devel.html for
the FreeBSD ports of the RTEMS tools.
Jim
/"\   ASCII Ribbon Campaign  .
\ / - NO HTML/RTF in e-mail  .
 X  - NO Word docs in e-mail .
jeh at FreeBSD.org      http://www.FreeBSD.org     The Power to Serve
jim at TheHousleys.Net  http://www.TheHousleys.net
The wise man built his network upon Un*x.
    The foolish man built his network upon Windows.
