RTEMS Build Problems on OpenBSD
Mon Mar 5 22:20:27 UTC 2001
Mike Siers wrote:
> Hi,
> I took your advice and I switched back to use the 4.5.0 released version of
> RTEMS.
> I am still using the newer versions of the build tools.  I tried compling
> RTEMS and this
> time I got an error saying it could not find make.  I copied gmake to make
> and I was
> able to successfully build RTEMS!!
YEAH!
> Should I switch back to the version of the build tools that are specified
> with for
> version 4.5.0?
Yes.  There are some inconsistencies with the division of header
files between newlib and RTEMS between the versions specified for
snapshots and the release.
> Also, if you want to build the latest snapshot, what build
> scripts
> should you use?
The same ones with different version numbers.
> Thanks for your help
> Mike Siers
> -----Original Message-----
> From: siosion at sos1.sos.com.pl [mailto:siosion at sos1.sos.com.pl]On Behalf Of
> Adam Szeliga
> Sent: Monday, March 05, 2001 3:07 PM
> To: rtems-users at oarcorp.com
> Subject: Re: RTEMS Build Problems on OpenBSD
> I think that you should return to rtems version 4.5.0.
> You have mixed veriosn of tools and rtems system.
> Adam Szeliga
> Mike Siers wrote:
> > Hi,
> > I switched to use the following versions of the c tool files:
> >   binutils-2.10 with patch dated 2000-11-02
> >   gcc-2.95.2    with patch dated 2000-12-26
> >   newlib-1.8.2  with patch dated 2000-08-28
> >   c_build_scripts-4.5.0
