How could I get a working RTEMS source?
open_sky
open_sky at sina.com
Thu Mar 8 12:09:08 UTC 2001
hi,
I have downloaded the sources needed to create the cross compiler for rtems-4.5.0-beta1b from www.oarcorp.com/rtems/beta/rtems-4.5.0-beta/src, and built it successfully. But I could only get the rtems-4.5.0-beta1c.tgz from that site, and it doesn't work!!!
I also downloaded all sources needed to build the cross compiler for rtems-4.5.0 and itself, but it also couldn't be built successfully for all options, even if I built them successfully when I made some modification in a Makefile.in and switched the posix ,TCP/IP and test options off.
Could you help me in the following aspects:
----tell me a site to download rtems-4.5.0-beta1b.tgz
or
----tell me a way and needed sources to build rtems-4.0.0
Sincerely,
James Zhang(zjw)
______________________________________
