Definitely something funny with the mcp750
gregory.menke at gsfc.nasa.gov
Thu Mar 8 20:00:59 UTC 2001
Attached is the full trickle of an example exception. I can cause the
exception at will by including a C file that contains 1100 or so bytes
of static data, arranged as follows;
char confdata[]= "......
The data itself is the contents of an ascii config file, no graphics
chars. The file into which I'm including/not including the file above
is the rtems startup code, which I'd be happy to supply as needed.
If I don't include the file that has the definition of confdata above,
then RTEMS starts up happily. If I do include it, then RTEMS bombs as
shown below. If its verboten to include data defined in such a way,
please tell what way it should be done...
I'm using the linux hosted tools on a 2.2.18 Debian system.
Thanks,
Gregm
Copyright Motorola Inc. 1988 - 1998, All Rights Reserved
PPC1 Debugger/Diagnostics Release Version 4.1 - 10/12/98 RM01
COLD Start
Local Memory Found =02000000 (&33554432)
WARNING: Board Configuration Data Failure
MPU Clock Speed =233Mhz
BUS Clock Speed =67Mhz
WARNING: Keyboard Not Connected
Reset Vector Location : ROM Bank B
Mezzanine Configuration: Single-MPU
Current 60X-Bus Master : MPU0
Idle MPU(s) : NONE
System Memory: 32MB, ECC Enabled (ECC-Memory Detected)
L2Cache: 1024KB, 117Mhz
PPC1-Bug>nbo
Network Booting from: DEC21140, Controller 0, Device 0
Device Name: /pci at 80000000/pci1011,9 at e,0:0,0
Loading: bootimage
Client IP Address = 128.183.234.80
Server IP Address = 128.183.235.130
Gateway IP Address = 128.183.232.1
Subnet IP Address Mask = 255.255.252.0
Boot File Name = bootimage
Argument File Name =
Network Boot File load in progress... To abort hit <BREAK>
Bytes Received =&250648, Bytes Loaded =&250648
Bytes/Second =&250648, Elapsed Time =1 Second(s)
Residual-Data Located at: $01F78000
Model: (e2)
Serial: MOT0000000
Processor/Bus frequencies (Hz): 233347744/66670784
Time Base Divisor: 4000
Memory Size: 2000000
Original MSR: 3040
Original HID0: 80a4
Original R31: 0
PCI: Probing PCI hardware
RTEMS 4.x/PPC load:
Uncompressing the kernel...
Kernel at 0x00000000, size=0x76670
Initrd at 0x00000000, size=0x0
Residual data at 0x00077000
Command line at 0x0007e000
done
Now booting...
Welcome to RTEMS RELEASE rtems-4.5.0(PowerPC/PowerPC 750/mcp750) on Mesquite cPCI (MCP750)
RTEMS RELEASE rtems-4.5.0(PowerPC/PowerPC 750/mcp750) PANIC OpenPic Not found
exception handler called for exception 12
Next PC or Address of fault = 12cc8
Saved MSR = 3032
R0 = 12cc4
R1 = 775b0
R2 = 0
R3 = 4f
R4 = 5ab28
R5 = 0
R6 = 0
R7 = 77590
R8 = 77180
R9 = 800003f8
R10 = 5c9d4
R11 = 20
R12 = ffffffff
R13 = 1f73d40
R14 = 0
R15 = 0
R16 = 0
R17 = 0
R18 = 0
R19 = 0
R20 = 0
R21 = 0
R22 = 74ef4
R23 = ffffffff
R24 = 7e00f
R25 = 6e4b0
R26 = 5ff14
R27 = 6e480
R28 = 60000
R29 = 60000
R30 = 62674
R31 = 775c0
CR = 28800024
CTR = 0
XER = 20000000
LR = 12cc4
MSR = 60000
unrecoverable exception!!! Push reset button
