better sizes Re: ACE/TAO on RTEMS
Fri Mar 16 19:03:55 UTC 2001
OK.  Now that I have worked out the kinks and gotten
the "ace_main" called from our init task, the linker
actually has to include stuff.  Here are some sizes.
bash$ sparc-rtems-size A*Test
   text	   data	    bss	    dec	    hex	filename
1246128	  14768	  39700	1300596	 13d874	ARGV_Test
1224784	  14768	  39700	1279252	 138514	Aio_Platform_Test
1223888	  14768	  39700	1278356	 138194	Atomic_Op_Test
1254512	  14960	  39700	1309172	 13f9f4	Auto_IncDec_Test
How does this look Rosimildo?  These are still just ACE.  I need
to rebuild TAO and the ORB  services to get TAO numbers.
Before the sections stuff, I was about to post a patch.  Once
I link a TAO test, I will do so.
--joel
Joel Sherrill wrote:
> Sergei Organov wrote:
> > "Rosimildo daSilva" <rdasilva at connecttel.com> writes:
> > > From: Sergei Organov <osv at javad.ru>
> > > To: rtems-users at oarcorp.com <rtems-users at oarcorp.com>
> > > Date: Friday, March 16, 2001 11:07 AM
> > > Subject: Re: ACE/TAO on RTEMS
> > > >Are gcc flag '-ffunction-sections' and ld flag '--gc-sections' available
> > > for
> > > >your target? Do you use them?
> > > I really like to hear if these makes difference.  I added them to a
> > > makefile and I did not notice much difference. But, I did not tried
> > > hard enough.  I started getting bizzar linking errors, and suddenly,
> > > the order of the libraries started matter. I guess, I did something
> > > wrong.
> > It really makes difference when you have a lot of routines in one object file
> > only few of which are used. It effectively makes all your object files
> > libraries. Don't know if it's the case with ACE/TAO.
> > I haven't got any troubles using these options after I've changed all
> > '*(.text)' to '*(.text*)' in my linker command files.
> I did this and it worked.  I don't know that I trust the resulting
> executables.  Strangely, they are now all the same size. :)
> bash$ sparc-rtems-size *Test
>  234768    4544   22796  262108   3ffdc ARGV_Test
>  234768    4544   22796  262108   3ffdc Aio_Platform_Test
> I think this is because the test is now actually not being linked
> in since it is a C++ main. :)
> It certainly reduced the size though.
> Now I am facing the standard problem that the tests have
> a "main()" and I need to get to it.    Ralf/Eric .. have we
> gotten to the point where we can move the init/fini code
> and have main in user space?
> > Sergei.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>    Support Available             (256) 722-9985
