RTEMS event send/receive - events apparently lost.
Nick.SIMON at syntegra.bt.co.uk
Wed Mar 21 12:57:22 UTC 2001
Is anyone aware of a problem in events in rtems 4.5.0 beta 3a?
I have a task which waits for time and frame events like this:
while(1)
rtems_event_set got;
sc = rtems_event_receive(ITS_ETH_EVENT | ITS_TIM_EVENT,
RTEMS_WAIT | RTEMS_EVENT_ANY,
0,
&got);
// Process incoming ethernet packets
if(got & ITS_ETH_EVENT)
// Received one or more packets
int len;
while((len = pkt.pktRcv()) != 0)
if(pkt.isCbpId())
pkt.dispatch();
else
printf("ITS - unrecognised packet header.\n");
// Process timer tick
if(got & ITS_TIM_EVENT)
TimerManager::instance()->tick();
} // end main event loop
On occasion we seem to miss ITS_ETH_EVENTs (we may also be missing TIM
events, I don't know), possibly as a result of the two events being sent in
close time proximity to each other.
The ETH event is sent by another task, and the TIM event is from a timer
service routine (is that an issue?).
Is anyone else aware of a problem in this area? Processor is mpc860, and
BSP is based on eth-comm BTW. I can work around this by always checking for
incoming frames instead of testing the event flag (i.e. lose the line
"if(got & ITS_ETH_EVENT)").
TIA,
-- Nick Simon
Check us out at http://www.syntegra.com
