make error building rtems under cygwin
Andrew Maximov amaximus at mail.ru
Mon Mar 26 18:28:27 UTC 2001
> -----Original Message-----
> From: Chris Stich [mailto:cstich at decrc.abb.de]
> Sent: Monday, March 26, 2001 9:44 PM
> To: Andrew Maximov; Rtems-Users
> Subject: Re: make error building rtems under cygwin
> Hi,
> ok, I deleted all long paths in the path var in my 2k-environment, but I
> got the same error as before.
> Cheers, Chris
> > > Sent: Monday, March 26, 2001 2:04 PM
> > > To: Rtems-Users
> > > Subject: make error building rtems under cygwin
> > > Hello,
> > > I'm one step closer to my rtems, but now I got this error.
> > > After configure I started make all:
> > > <...snap>
> > > Making preinstall in unix
> > > gmake[7]: Entering directory
> > > `/home/pecos/build-rtems/c/posix/exec/score/cpu/uni
> > > x'
> > > Makefile:605: *** multiple target patterns.  Stop.
> > > gmake[7]: Leaving directory
> > > `/home/pecos/build-rtems/c/posix/exec/score/cpu/unix
> > > gmake[6]: *** [preinstall-recursive] Error 1
> > > gmake[6]: Leaving directory
> > > `/home/pecos/build-rtems/c/posix/exec/score/cpu'
> > > gmake[5]: *** [preinstall-recursive] Error 1
> > > gmake[5]: Leaving directory
> `/home/pecos/build-rtems/c/posix/exec/score'
> > > gmake[4]: *** [preinstall-recursive] Error 1
> > > gmake[4]: Leaving directory `/home/pecos/build-rtems/c/posix/exec'
> > > gmake[3]: *** [preinstall-recursive] Error 1
> > > gmake[3]: Leaving directory `/home/pecos/build-rtems/c/posix'
> > > gmake[2]: *** [posix] Error 1
> > > gmake[2]: Leaving directory `/home/pecos/build-rtems/c'
> > > gmake[1]: *** [all-recursive] Error 1
> > > gmake[1]: Leaving directory `/home/pecos/build-rtems/c'
> > > make: *** [all-recursive] Error 1
> > > Does anyone have an idea?
> > > At the moment I use rtems snapshot 220100, cygwin 1.1.8 and Window 2k.
> > > Kind regards, Chris
> > Check PATH enviroment variable.
> > It shoud not contain long filenames with spaces.
> > Ex: PATH=D:\Program files\Visual Studio etc..
I solved absolutely same problem.
I precisely remember that I have decided it by
eliminating lengthy names with blanks from $PATH.
What does the variable PATH contain?
Did you start "configure" again?
