ACE/TAO 5.1 RTEMS patch available
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Mar 27 14:59:45 UTC 2001
TAO is an open source real-time CORBA implementation. Full information
is at:
http://www.cs.wustl.edu/~schmidt/TAO.html
I have done a "compile-only" port to RTEMS. It compiles
cleanly and tests do link. The configuration is pretty
much BSP independent. There is a "Makefile.rtems" which
uses the RTEMS application Makefile infrastructure but
answers questions like "what is the name of the compiler?"
and "what arguments do I use?" The only exception to this
is that the arguments to use per function sections are
always added so you probably need a recent ELF toolset to
use this unmodified.
The patch and a README are at:
ftp://ftp.oarcorp.com/pub/rtems/snapshots/contrib/ACE-TAO/
Ignoring the fact that I have not actually run a test, the
worst problem is that their directory descent rule in
include/makeinclude/rules.nested.GNU is complaining like this
and not descending.
/bin/sh: unexpected EOF while looking for `''
/bin/sh: -c: line 2: syntax error
I have reported this twice to the taobugs mailing list
and gotten no response. The most recent post is at:
http://groups.yahoo.com/group/tao-bugs/message/1066
If someone can fix this, it would be great.
One final warning, I did this with the current source. I
found one RTEMS .h file (sys/utsname.h) that did not
have proper C++ wrapping.
Hopefully someone is interested enough in this to
try to compile and test it for real. :)
Enjoy and discuss this freely on the lists.
joel at OARcorp.com On-Line Applications Research
