ACE/TAO on RTEMS
Rosimildo daSilva rdasilva at connecttel.com
Fri Mar 16 17:12:30 UTC 2001
To: rtems-users at OARcorp.com <rtems-users at OARcorp.com>
Date: Friday, March 16, 2001 10:44 AM
Subject: ACE/TAO on RTEMS
>I am havnig some initial success building ACE/TAO.  I have
>managed to build ACE and link all the tests without error.
>I am now compiling TAO.  It appears that the ACE test executables
>are quite large.  Any thoughts:
>bash$ sparc-rtems-size *Test
>   text    data     bss     dec     hex filename
>2156192 139232   43796 2339220 23b194 ARGV_Test
>2156448 139104   43796 2339348 23b214 Aio_Platform_Test
>2158960 139888   43796 2342644 23bef4 Atomic_Op_Test
>2164400 140016   43796 2348212 23d4b4 Auto_IncDec_Test
>2156928 139104   43796 2339828 23b3f4 Barrier_Test
>2155728 139136   43796 2338660 23af64 Basic_Types_Test
>2167744 140592   43796 2352132 23e404 Buffer_Stream_Test
>2247104 142688   43796 2433588 252234 CDR_File_Test
>2207968 141376   43796 2393140 248434 CDR_Test
>2263824 144928   43796 2452548 256c44 Cache_Map_Manager_Test
>2378256 157392   43796 2579444 275bf4 Cached_Accept_Conn_Test
>2359312 154544   43796 2557652 2706d4 Cached_Conn_Test
>2204864 141872   43796 2390532 247a04 Capabilities_Test
>I am looking at real .text, not executable file size so that
>mistake is out.
The sizes looks ok. They're inline with the ones that I saw
a long time ago. Around 80% larger than ones for OmniORB.
The only strange thing is that these are ACE only. You need
to add TAO, and the executable size most likely will double.
>This is a lot of C++ code so there might be some bad combination
>of options that is contributing to things.  The compile options
>are "-fno-implicit-templates -fno-rtti -DACE_LACKS_RTTI ".  Could
>I do better?
I do not think so. You are removing RTTI that takes some space,
and is hardly used.
>I know ACE/TAO can be subsetted but am not looking at that since
>I am focuing on building everything. :)
This is good.
Rosimildo.
