Cygwin Build
Gerke Kok gerke.kok at tpa-nl.com
Fri May 4 06:17:34 UTC 2001
I gues you should look in the mailing list. It is something like that you
dont have a path to the right CC.EXE or that the path is not mounted binary.
It has been on this list before! Good luck.
wkr,
Gerke
> -----Oorspronkelijk bericht-----
> Van: Paul Evans [mailto:paule at martex.gen.oh.us]
> Verzonden: donderdag 3 mei 2001 19:27
> Aan: rtems-users at oarcorp.com
> Onderwerp: Cygwin Build
> Hello All,
> I'm having a problem building RTEMS-4.5.0 under the current Cygwin
> environment. It would appear from the configure output that Cygwin
> isn't being detected. Is this an autoconf problem  that can
> be overridden,
> or a symptom of something else? (The toolchain is the
> precompiled one from
> OAR and is working correctly)
> Thanks for any help,
>     -Paul
> --Output follows (PS1 is 2 lines)--
> paule at PIPPIN ~
> $ set | grep ^PATH=
> PATH=/opt/rtems/bin:/usr/local/bin:/usr/bin:/bin:/c/Python21:/
> c/Perl/bin:/c/
> WINN
> T/system32:/c/WINNT:/c/WINNT/System32/Wbem
> paule at PIPPIN ~/build
> $ cat build_cmd
> ../rtems-4.5.0/configure --target=m68k \
>     --disable-posix --disable-tcpip --disable-cxx \
>     --enable-rtemsbsp=m68k-rtems\
>     --prefix=/opt/rtems
> $ bash build_cmd
> loading cache ./config.cache
> checking for RTEMS Version... 4.5.0
> checking host system type... i386-pc-cygwin32
> checking target system type... m68k-unknown-none
> checking build system type... i386-pc-cygwin32
> checking rtems target cpu... m68k
> checking for a BSD compatible install... (cached) /usr/bin/install -c
> checking whether build environment is sane... yes
> checking whether make sets ${MAKE}... (cached) yes
> checking for working aclocal... found
> checking for working autoconf... found
> checking for working automake... found
> checking for working autoheader... found
> checking for working makeinfo... found
> checking whether to enable maintainer-specific portions of
> Makefiles... no
> checking if the test suites are enabled? ... no
> checking if cpu m68k is supported... yes
> creating ./config.status
> creating Makefile
> creating tools/Makefile
> creating make/Makefile
> creating make/custom/Makefile
> creating make/Templates/Makefile
> creating make/compilers/Makefile
> creating doc/Makefile
> configuring in tools/build
> running /bin/sh
> ../../../rtems-4.5.0/tools/build/configure  --target=m68k --disa
> --enable-rtemsbsp=m68k-rtems --prefi
> x=/o
> pt/rtems --cache-file=../.././config.cache
> --srcdir=../../../rtems-4.5.0/too
> ls/b
> uild
> loading cache ../.././config.cache
> Makefiles... no
> checking for Cygwin environment... no
> checking for mingw32 environment... no
> checking for executable suffix... configure: error: installation or
> configuratio
> n problem: compiler cannot create executables.
> configure: error: ../../../rtems-4.5.0/tools/build/configure
> failed for
> tools/bu
> ild
