Problems by listing files opendir (".")
Joel Sherrill
joel.sherrill at OARcorp.com
Fri May 4 14:42:04 UTC 2001
Markus Schmitz wrote:
> Hello,
> I run RTEMS on cygwin.
> I tried to list the files in a directory,
> but all I got were empty strings?
Is the target also Cygwin? If so, then I suspect, this is the
expected behavior since file IO is not supported on the UNIX
simulation ports.
> #include <stdio.h>
> #include<bsp.h>
> #include<sys/types.h>
> #include<sys/stat.h>
> #include<dirent.h>
> #include<stdio.h>
> #include<unistd.h>
> #include<stdlib.h>
> #include<string.h>
> #include<errno.h>
> #include <fcntl.h>
> rtems_task Init(rtems_task_argument ignored)
> DIR *dp;
> struct dirent *dirp;
> dirp = new dirent;
> if ( (dp = opendir (".")) == NULL)
> {printf("can`t open Directory");}
> else
> while( (dirp = readdir(dp)) != NULL)
> printf("d_ino %d, d_off %ld d_reclen %d d_namlen
> %d d_name %s\n", dirp->d_ino, dirp->d_off,
> dirp->d_reclen, dirp->d_namlen, dirp->d_name);
> closedir(dp);
> exit(0);
> /* configuration information */
> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 100
> #define CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_MAXIMUM_TASKS 10
> #define CONFIGURE_MAXIMUM_PERIODS 1
> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 2
> #define CONFIGURE_MAXIMUM_SEMAPHORE 2
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_INIT
> #include <confdefs.h>
> $ lstest6.exe
> d_ino 1627903676, d_off 1627903676 d_reclen 0 d_namlen
> 0 d_name
> 0 d_name
> 0 d_name
> 0 d_name
> 0 d_name
> Thanks
> Markus
> __________________________________________________________________
> Do You Yahoo!?
> Gesendet von Yahoo! Mail - http://mail.yahoo.de
joel at OARcorp.com On-Line Applications Research
