i386/parallel port
Fernando RUIZ CASAS (E-mail) fernando.ruiz at ctv.es
Tue May 8 11:05:11 UTC 2001
> -----Mensaje original-----
> De: rwas rwas [mailto:mc68332 at yahoo.com]
> Enviado el: viernes, 04 de mayo de 2001 20:35
> Para: rtems-users at oarcorp.com
> Asunto: i386/parallel port
> Hello,
> I'm new to the RTEMS world.
> I've taken a look in the bsp for the pc386 and don't
> see anything covering the parallel port.
> Has anyone here had any experience with using the
> parallel port with rtems?
> I'm also curious if rtems will be moving towards
> dynamically loadable tasks and a user interface
> similar to VxWorks.
I'm working around the multiuser shell environment.
The system on VxWorks isn't known by me.
If you can explain me the environment perhaps I can work in this line.
I'm preparing a rudimentary telnetd support with tcp/ip in order
to provide remote shell console access but with independent session for
every sesion opened.
The commands that you can execute in this shell are extensible.
With only a
   shell_add_cmd("command_name","help_topic","help
description",main_cmd_proc)
will be necesary to run the new commands.
And the header for the new 'main_cmd_proc' is the standard main_proc in
every 'C' program
	int main_cmd_proc(int argc,char * argv[]);
You can run the 'C' programs but with a little restrictions.
A call of
   rtems_telnetd_initialize();
starts the telnetd daemon and
the remote console will be ready to control the BSP.
Of course you can start a shell in every ttydriver that you need.
Serial, VGA console, etc...
Only a termios drivers is necesary.
See you the last snapshot (20010424)in c/src/libmisc/shell repository for
the shell for ttydriver.
Questions, Sugg?
Please don't hesitate to ask me.
Fernando RUIZ CASAS
home:correo at fernando-ruiz.com
work:fernando.ruiz at ctv.es
> Thanks.
> Robert W.
> __________________________________________________
> Do You Yahoo!?
> Yahoo! Auctions - buy the things you want at great prices
> http://auctions.yahoo.com/
