dynamic loading was Re: i386/parallel port
Tue May 8 16:31:13 UTC 2001
rwas rwas wrote:
> Tools? You mean libs right?
> I'd have to assume that RTEMS has it's own scheduler
> database and format. And I suspect it'd be hard to
> pull off for a novice since RTEMS now must be have
> tasks linked in at compile time. That makes me wonder
> why they have'nt done it yet.
It isn't a matter of difficulty -- at least two users
have come up with their own dynamic loading scheme.
It is more a matter of time of someone taking the time
to specify a loading mechanism that is reasonably target
independent.  Since we use the GNU tools, there is really
no magic on generating the pieces -- just getting them
to the target and initializing them.
Chris Johns has a setup with his My Right Boot that
does exactly what you are suggesting.  This is a useful
feature and I would be very happy to see it addressed
in a general sense.
> I suspect the shell would have to be hacked
> considerably.
> It does'nt sound as easy as you seem to indicate.
As Fernando posted earlier, this too is coming along. :)
> --- gregory.menke at gsfc.nasa.gov wrote:
> >  > I'm also curious if rtems will be moving towards
> >  > dynamically loadable tasks and a user interface
> >  > similar to VxWorks.
> > It relies on the GNU toolchain, just like vxWorks,
> > so you can use
> > whatever GUI tools suit your fancy.
> > Gregm
> __________________________________________________
> Do You Yahoo!?
> Yahoo! Auctions - buy the things you want at great prices
> http://auctions.yahoo.com/
