Problems running the BIT_ADA script
Thu May 10 11:48:49 UTC 2001
I do not believe gnat 3.13p (based on gcc 2.8.1) supports
i386-elf as an embedded target.  It looks like it is getting
confused.
<sigh>  I wish they would release a version based on a modern
gcc so we would be in sync again. <sigh>
--joel
Sergio wrote:
> I'm trying install RTEMS 4.5.0 (GNAT version).
> When I run the bit_ada script I get the following error:
> >gcc -c -O2 -I. -I../../src/libiberty/../include
> ../../src/libiberty/cplus-dem.c
> >../../src/libiberty/cplus-dem.c:35:22: demangle.h: No such file or
> directory
> >gmake[1]: *** [cplus-dem.o] Error 1
> >gmake[1]: Leaving directory `/tmp/rtems/tools/build-i386-tools/libiberty'
> >gmake: *** [all-libiberty] Error 2
> >+ check_fatal 2 '**** FAILED **** base build of C and C++ (step 1)'
> >+ '[' 2 -ne 0 ']'
> >+ shift
> >+ echo 'ERROR: **** FAILED **** base build of C and C++ (step 1)'
> I think that there is a problem with the links in the src directory.
> I can reach the file demangle.h in the specified location following the
> links, but seems that gcc doesn't.
> I have RedHat 7.0.
> Can someone help me?
> Thanks.
