RTEMS and Ada: What is the current status ?
Laurent Guerby guerby at acm.org
Thu May 24 15:43:53 UTC 2001
Richard Kenner posted the following message on 22May2001:
<http://gcc.gnu.org/ml/gcc/2001-05/msg01148.html>
There is now a set of files for Ada that seem reasonable to add to the GCC
tree.  They would be in a separate (ada) subdirectory and no changes to other
files are needed for them to work.  If a machine does not already have GNAT
installed, that subdirectory will not be configured in (because it's mostly
in Ada).
Both to pick a good date and because I'll be away from tomorrow until May 30,
I propose adding the files on June 1.
Are there any objections/issues to doing so?
This is very good news for RTEMS/Ada user, of course some work will be
needed to get GNAT/GCC3/RTEMS working but at least everything can be
done in the open and Ada will stay up to date in the future.
Laurent Guerby <guerby at acm.org>
