Building or1k/rtems
Ivan Guzvinec ivang at opencores.org
Tue Nov 13 13:19:12 UTC 2001
Hi,
I'm trying to build RTEMS port for openrisc1k and I'm having absolutely
no success with the task. I'll just explain the whole thing and hope
that there is someone out there that has done this.
OR1K RTEMS port can be found at:
http://www.opencores.org/cores/or1k-new/rtems/
Compile/install instructions in README.or1k read that ./configure should
be run, but the distribution does not contain configure scripts. I
figured out that I must use autoconf to generate configure script, but
since I have never used autoconf, my attempt was not successful.
Generated configure script displays folowing error message:
    loading cache ./config.cache
    ../configure: line 527: syntax error near unexpected token
`RTEMS_TOP(.)'
    ../configure: line 527: `RTEMS_TOP(.)'
Can anyone please help me with a description of how to build configure
script and other files that are missing (Makefile.in, aclocal.m4).
regards,
    Ivan
