use pppd
Stan zylog at club-internet.fr
Sun Nov 25 20:38:34 UTC 2001
  ----- Original Message -----
  To: Stan
  Cc: rtems-users at oarcorp.com
  Sent: Tuesday, November 13, 2001 8:29 PM
  Subject: RE: use pppd
  Hi Stan,
  The best place to look is at the example code in the pppd directory under
  the latest snapshot.
I use RTEMS 4.5.0, did you have an example for that ?
  The only difference between using a serial port vs. a modem is that you need
  to set up the chat program/function dialing scripts.  These scripts send different
  strings to the modem.
 All right.
Thanks.
Stan.
  Good Luck
  Mike Siers
    -----Original Message-----
    Sent: Tuesday, November 13, 2001 12:13 PM
    To: rtems-users at oarcorp.com
    Subject: use pppd
    hello,
    What are the different steps for use a pppd ?
    1 - over tty
    2 - over modem
    Thanks.
URL: <http://lists.rtems.org/pipermail/users/attachments/20011125/141d23f7/attachment.html>
