use pppd
Mike Siers
mikes at poliac.com
Mon Nov 26 15:00:41 UTC 2001
Hi Stan,
No, pppd is only available in the newer snapshots.
Mike Siers
-----Original Message-----
Sent: Sunday, November 25, 2001 2:39 PM
To: Mike Siers
Cc: rtems-users at oarcorp.com
Subject: Re: use pppd
----- Original Message -----
To: Stan
Sent: Tuesday, November 13, 2001 8:29 PM
Subject: RE: use pppd
Hi Stan,
The best place to look is at the example code in the pppd directory
under
the latest snapshot.
I use RTEMS 4.5.0, did you have an example for that ?
The only difference between using a serial port vs. a modem is that you
need
to set up the chat program/function dialing scripts. These scripts send
different
strings to the modem.
All right.
Thanks.
Stan.
Good Luck
Mike Siers
Sent: Tuesday, November 13, 2001 12:13 PM
To: rtems-users at oarcorp.com
Subject: use pppd
hello,
What are the different steps for use a pppd ?
1 - over tty
2 - over modem
Thanks.
URL: <http://lists.rtems.org/pipermail/users/attachments/20011126/d3d06260/attachment.html>
