leon1 Re: undefined reference to `_CPU_Context_restore_fp'
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Nov 15 18:05:30 UTC 2001
Jiri Gaisler wrote:
> Joel Sherrill wrote:
> > What version of RTEMS is this with? Is it a standard OAR distribution
> > or Jiri Gaisler's 4.5.0+? This sounds like a simple mistake in
> > thread.inl where restart is not honoring soft float. We just need to
> > know the version.
> I get the same problem on my version (4.5.0+). There seems to be
> two thread.inl:
> exec/score/inline/rtems/score/thread.inl
> exec/score/macros/rtems/score/thread.inl
> Both of them calls various FPU save/restore functions. I guess these
> functions should be define as empty if not FPU is configured....?
I think all FPU operations are protected in the CVS trunk source but
not in the 4.5 branch. I have extracted the patch that was on the trunk.
Try applying it to the two files in question.
Let me know if this works and I will merge the patch onto the 4.5-branch
so pre3 has it.
> Jiri.
> Gaisler Research, Stora Nygatan 13, 411 08 Goteborg, Sweden, +46-31802405
> fax: +44-870-1361460 email: info at gaisler.com, home page: www.gaisler.com
joel at OARcorp.com On-Line Applications Research
RCS file: /usr1/CVS/rtems/c/src/exec/score/macros/rtems/score/thread.inl,v
retrieving revision 1.10
retrieving revision 1.11
diff -u -r1.10 -r1.11
--- rtems/c/src/exec/score/macros/rtems/score/thread.inl 1999/11/17 17:50:38 1.10
+++ rtems/c/src/exec/score/macros/rtems/score/thread.inl 2000/07/26 19:26:27 1.11
@@ -10,7 +10,7 @@
* found in the file LICENSE in this distribution or at
* http://www.OARcorp.com/rtems/license.html.
- * $Id: thread.inl,v 1.10 1999/11/17 17:50:38 joel Exp $
+ * $Id: thread.inl,v 1.11 2000/07/26 19:26:27 joel Exp $
#ifndef __THREAD_inl
@@ -67,6 +67,7 @@
+#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
#define _Thread_Restart_self() \
if ( _Thread_Executing->fp_context != NULL ) \
@@ -74,6 +75,12 @@
_CPU_Context_Restart_self( &_Thread_Executing->Registers ); \
+#else
+#define _Thread_Restart_self() \
+ _CPU_Context_Restart_self( &_Thread_Executing->Registers ); \
+#endif
/*PAGE
@@ -96,8 +103,10 @@
#define _Thread_Is_allocated_fp( _the_thread ) \
( (_the_thread) == _Thread_Allocated_fp )
+#endif
/*PAGE
@@ -105,8 +114,10 @@
#define _Thread_Deallocate_fp() \
_Thread_Allocated_fp = NULL
+#endif
/*PAGE
RCS file: /usr1/CVS/rtems/c/src/exec/score/inline/rtems/score/thread.inl,v
retrieving revision 1.14
retrieving revision 1.15
diff -u -r1.14 -r1.15
--- rtems/c/src/exec/score/inline/rtems/score/thread.inl 1999/11/17 17:50:37 1.14
+++ rtems/c/src/exec/score/inline/rtems/score/thread.inl 2000/07/26 19:26:27 1.15
@@ -10,7 +10,7 @@
- * $Id: thread.inl,v 1.14 1999/11/17 17:50:37 joel Exp $
+ * $Id: thread.inl,v 1.15 2000/07/26 19:26:27 joel Exp $
@@ -111,8 +111,10 @@
RTEMS_INLINE_ROUTINE void _Thread_Restart_self( void )
_Context_Restore_fp( &_Thread_Executing->fp_context );
+#endif
@@ -144,12 +146,14 @@
* FALSE otherwise.
RTEMS_INLINE_ROUTINE boolean _Thread_Is_allocated_fp (
Thread_Control *the_thread
return ( the_thread == _Thread_Allocated_fp );
+#endif
/*PAGE
@@ -161,10 +165,12 @@
* point context is now longer associated with an active thread.
RTEMS_INLINE_ROUTINE void _Thread_Deallocate_fp( void )
_Thread_Allocated_fp = NULL;
+#endif
/*PAGE
