termios+PTY=real-time killer? (was Re: Interrupt Latency on PPC)
Till Straumann strauman at SLAC.Stanford.EDU
Fri Nov 16 20:20:32 UTC 2001
"Fernando RUIZ CASAS (E-mail)" wrote:
> Hi.
>  Is the PTY driver the pty.c file placed close to telnetd.c?
>  This pty driver doesn't make any special thing with termios.
>  If the tcp/ip works fine the driver also.
We are talking about the very one. I agree, pty.c does not do anything
special. However, termios [under some circumstances] calls
pty's pollWrite() function with _Interrupts_disabled_:
  rtems_interrupt_disable(level);
  tty->device.write(...);
  rtems_interrupt_enable(level);
Because PTY's pollWrite() does socket/IO, I guess it could even
block! - Or am I missing something?
I suppose that termios could relax its interrupt-disabling policy
in task driven mode. PTY should then probably be run in task
driven or polled mode.
-- Till
> Perhaps I'm speaking about other oignons.
> Fernando RUIZ CASAS
> home:correo at fenando-ruiz.com
> work:fernando.ruiz at ctv.es
> -----Mensaje original-----
> De: till at MAILBOX.SLAC.Stanford.EDU
> [mailto:till at MAILBOX.SLAC.Stanford.EDU]En nombre de Till Straumann
> Enviado el: viernes, 16 de noviembre de 2001 2:26
> Para: RTEMS List; joel.sherrill at oarcorp.com
> Asunto: Re: Interrupt Latency on PPC
> Things get _really_ bad when the PTY driver is
> heavily used. I measured IRQ latencies of ~200us
> during quite short measurement intervals (remember,
> we're doing statistics here). This is in the order of
> 100 times the average.
> I guess that the problem is caused by termios.c
> which under some circumstances calls the
> device's 'write' callback with _IRQs_disabled_.
> The PTY driver's write callback is a
> write(socket,...)
> outchh!
> Is there a termios expert out there who could explain
> to me what really needs to be protected from interrupts?
> Also, shouldn't the PTY driver run in task driven
> (as opposed to the current IRQ driven) mode?
> write(socket,...)
> outchh!
> -- Till.
