Linux build
Mon Nov 19 23:20:58 UTC 2001
The mrm332 BSP is in the snapshots.  It also looks like you
are using tools for the snapshots so you might as well switch
and get the right BSP.
--joel
Duane Gustavus wrote:
> Hello Folks,
> I have a Robomind 68332 card that has been mentioned on this list
> before.  I am using Linux (RH 7.1) and have installed the GNU tools
> for 68k architecture using the supplied rpms (ie in /opt/rtems).  I
> have downloaded and unpacked the source in /opt/rtems to make
> /opt/rtems/rtems-4.5.0.  I have made an /opt/rtems/build-rtems
> directory, cd'd into it and run ../rtems-4.5.0/configure
> --target=m68k-rtems --disable-itron --disable-networking.  This all
> seems to work correctly.
> For a make command, I am using make RTEMS_BPS="efi332".  I realize
> this will probably not build code loadable in my Robomind card, but it
> will verify that I can build RTEMS for a 68332 with the tools (a big
> step in the right direction).  The make goes for quite a bit building
> lots of modules without problems.  Then I get what appears to be some
> configuration error:
> make[5]: Entering directory `/export/rtems/build-rtems/m68k-rtems/c/efi332/exec/posix/src'
> mkdir o-optimize
> /opt/rtems/bin/m68k-rtems-gcc --pipe -B../../../../../../efi332/lib/ -specs bsp_specs -qrtems -g -Wall -ansi -fasm    -mcpu32     -c -D__RTEMS_INSIDE__ -O4 -fomit-frame-pointer -o o-optimize/adasupp.o ../../../../../../../rtems-4.5.0/c/src/exec/posix/src/adasupp.c
> In file included from ../../../../../../efi332/lib/include/sched.h:20,
>                  from /usr/include/pthread.h:20,
>                  from ../../../../../../../rtems-4.5.0/c/src/exec/posix/src/adasupp.c:7:
> /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../../m68k-rtems/include/sys/sched.h:44: field `ss_replenish_period' has incomplete type
> /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../../m68k-rtems/include/sys/sched.h:46: field `ss_initial_budget' has incomplete type
> I have looked at the sched.h file, and the ss_replenish_period and
> ss_initial_budget don't appear to be erroneous.  It looks suspicious
> to me that the /usr/include/pthread.h file is being included, but I
> don't really know what is going on there. BTW, the various reporting
> of /opt/rtems and /export/rtems above is caused by the fact that
> /opt/rtems in a symbolic link to /export/rtems (where the free disk
> space is).  On the theory that this might have something to do with
> the efi332 configuration, I tried one of the other BSPs mentioned in
> the configure exit message.  The result was the same, failing on the
> same file (with the exception of being in the mvme136 path).
> Up to this point everything has worked perfectly, so I am hoping this
> is not too big an issue (I am following the online docs and have
> checked them twice to see if I can spot what I'm doing wrong, but no
> joy).  I would certainly appreciate useful suggestions as how to
> proceed with the make.
> On another issue, the archives show some discussion of a BSP for the
> Robomind card (even pointing out that the efi332 BSP was a good
> starting point).  Did anyone ever make a useable BSP for this card?  I
> think RTEMS might be a great platform for a free robot environment if
> some inexpensive cards are supported for it.  I am willing to help
> with the MRM board if others are interested.
> Thanks for any info you can provide,
> Duane Gustavus
> Denton, TX
