problems adding targets to libfs
Matthew J Fletcher
amimjf at connectfree.co.uk
Thu Nov 29 13:49:36 UTC 2001
On Wednesday 28 Nov 2001 12:01 pm, Joel Sherrill wrote:
> > > 1. Did you run bootstrap in the libfs directory?
> > yes,. it complained about not having the EMBEDDED_C_ and UNIX_C
> > variables, but nothing else.
> If you are using the snapshots are you using the latest RTEMS autotools?
no, im using the generic GNU autotools, is there a diffrence ?
> > > I assume there is not a typo in the name libjffs.a. :)
> > > Is this the Linux JFFS? And did the licensing question get resolved?
> > well i took it from the 2.4.8 tree sources, but its hardly a linux fs
> > (looking at all the compatablity stuff that was added).
> > licensing,. ? (missed that discussion, sorry) its under the GPL2, jffs2
> > is issued under the GPL2 and RedHats eCos licence,..
> > is that a problem ?
> Read them closely for commercial use. I believe the GPL requires the
> code you link with it to become GPL
yep, my understanding is simmilar,.. im going to make a rash statement now
but why dont you go for the dual licencing that IBM / Mozilla / Sun use ?,
where suff is issued under a number of licnences, the user gets to pic and
choose what one they want to use.
for example if your a commerical company you can use the RTEMS licence
and you get to write all your own drivers / filesystems,,. and if your (well
anyone else), you can take it under the GPL and use the drivers and
filesystems that have been pulled over from linux,.
just an idea.
> and only RedHat can give commercial
> rights
> under the eCos license. I thought someone was porting the Linux flash
> memory device code and filesystem and had negotiated permission to
> include the RTEMS paragraph.
> NOTE: You said GPL2 and I don't know if you mean the vanilla GPL or
> a modified one.
nope, i just use GPL2 to distingush from the original GPL (but they are the
same, in all but icky legal details),.
regards
Matthew J Fletcher amimjf at connectfree.co.uk
Software Engineering Matthew.Fletcher at student.shu.ac.uk
www.amimjf.org ICQ amimjf 44193496
Since when did ignorance become a point of view ??
