Code- and heap- size
Jan.Suchotzki at de.abb.com
Mon Oct 8 07:33:17 UTC 2001
Hi,
that is very good. I already found the STACK_CHECKER, but not the function.
Thanks
Jan Suchotzki
(Embedded Eric Norum <eric.norum at usask.ca>@young.USask.Ca
image moved 05.10.2001 18:44
to file:
pic31240.pcx)
Sent by: Eric_Norum at young.USask.Ca
To: Jan.Suchotzki at de.abb.com
cc: rtems-users at oarcorp.com
Subject: Re: Code- and heap- size
Security Level:? Internal
Jan.Suchotzki at de.abb.com wrote:
> Hi,
> thank you, that is exactly what I was looking for.
> But it means, that I´m not able to get information about the
> memory used for local variables with functions like Heap_Get_information
> Jan Suchotzki
You can get information on per-task stack usage if you configure RTEMS
with the stack checking extension.
Just add
#define STACK_CHECKER_ON
in your configuration/initialization file somewhere before the
#include <confdefs.h>
line.
Then, in your program call Stack_check_Dump_usage() to print stack usage
statistics.
Eric Norum eric.norum at usask.ca
Department of Electrical Engineering Phone: (306) 966-5394
University of Saskatchewan FAX: (306) 966-5407
Saskatoon, Canada.
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20011008/a25bdcc7/attachment.obj>
