Termios Memory Leak
Thu Oct 11 20:53:41 UTC 2001
This will be in the next snapshot.  Thanks Mike for all you have
done with pppd.
For those who don't know, Mike has it quite stable in his own
lab.  I think pppd can finally move from experimental and
interesting to really really useful.  Please share some details
with us Mike.. set, baud rate, etc. :)
Congratulations to Mike. :)
Mike Siers wrote:
> Hi,
> While running a pppd test I found a memory leak in the termios
> software.  Basically the tty open function was allocating an input
> raw buffer, an output raw buffer, and a cooked buffer that were
> not getting released.  I have attached a patch for the latest
> snapshot.  The patch also has a fix to ensure the tty link list
> is updated correctly when a tty is closed.
> If you have any questions or concerns about this patch, please
> contact me.  I would like to get this fix merged into the source
> tree.
> Thanks
> Mike Siers
>    termios.diff    Type: unspecified type (application/octet-stream)
>                Encoding: quoted-printable
