National Semiconductor DP83815
Fri Oct 12 19:47:37 UTC 2001
Alex Holeczy wrote:
> On Thu, 11 Oct 2001, Joel Sherrill wrote:
> > Alex Holeczy wrote:
> > > Has anyone developed the chip support for the National Semiconductor
> > > DP83815 Ethernet Controller?
> > How does this relate to the DP83934CVUL?
> I do not know the answer to this question.
> I have just started looking at the data sheet for the DP83815 Ethernet
> Controller and I am not familiar with the DP83934 device.
The 83915 is an older device called the sonic.  It provided 10 mbit
support.  Looking in the Linux source I have, I do not see  any
references to that part number. Please do not lift source code
from Linux -- if you can't use the current sonic.c, then go to
a BSD tree and follow the RTEMS libchip style.
--joel
> Alex
> > > TIA
> > > Alex
> > > Alex Holeczy (alex at wmi.com)
> > > Communication Automation Corporation (CAC)      www.cacdsp.com www.wmi.com
> > > 1180 McDermott Drive, West Chester, PA  19380
> > > 800-367-6735 Ext. 122 or 610-692-9526 Ext. 122 (Voice)
> > > 610-436-8258 (Fax)
> 610-436-8258 (Fax)
