rtems 3c509 driver
Davide Del Vento davide_rtems at hotmail.com
Fri Oct 19 14:07:38 UTC 2001
Thank you: I've found it.
There was something that undid..
I find it without the dbg ;-)
But it doesn't work again ;-(
Now I get:
(snip)
ioctl() called.
Can't set default route: Network is unreachable.
Destination     Gatewaty/NetMask        bla
141.108.16.0    255.255.255.0           U
(snip)
but I think that it is only a network problem
Bye
;David
>In the debugger look at rtems_bsdnet_config and see what the
>first driver in the table actually is.  If you made this change
>correctly (i.e. nothing undid it for you), it should have
>worked. :(  So let's figure out what config you actually
>have.
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
