rtems_event_receive and timeslicing
Efren Serra efren.serra at Sun.COM
Tue Oct 23 16:07:57 UTC 2001
Brett,
I think should remove the RTEMS_TIMESLICE; it should not be used in real-time
systems.  Also, I suppose the tasks are going to communicate; so, one should be
waiting on a queue and the other should append to the queue.  This way neither
task hogs the CPU.
> I have a situation where I have two tasks running at the same priority (=
> 128). Both tasks were created with RTEMS_PREEMPT and
> RTEMS_TIMESLICE.
> One task is blocked, waiting on an event that is sent by an ISR.  The other
> task is in an infinite loop as follows:
> for ( ;; )
> The task that is blocked on the rtems_event_receive() never appears to
> receive the event.  However, if I place an
>  rtems_task_suspend( RTEMS_SELF );
> call prior to the infinite loop in the 2nd task - the first task does
> receive the event.
> I won't have this task construct in the near future as I implement more
> functionality, but I would like to understand if the blocked task should run
> under this situation with timeslicing enabled.  If I am missing some
> configuration options as well, I would like to know.
> I have
> #define CONFIGURE_TICKS_PER_TIMESLICE   50
> in my Initialization function file.
> I'm currently using the rtems-ss-20010816 snapshot.
> Thanks for any insight.
> Regards,
> Brett Swimley
