m68k bsp question
Stan zylog at club-internet.fr
Fri Oct 26 15:39:14 UTC 2001
hello,
Does anyone can explain why ' format_id = slot << 2' ?
void _CPU_Initialize(
  rtems_cpu_table  *cpu_table,
  void      (*thread_dispatch)      /* ignored on this CPU */
#if ( M68K_HAS_VBR == 0 )
  /* fill the isr redirect table with the code to place the format/id
     onto the stack */
  unsigned32 slot;
  for (slot = 0; slot < CPU_INTERRUPT_NUMBER_OF_VECTORS; slot++)
    _CPU_ISR_jump_table[slot].move_a7 = M68K_MOVE_A7;
    _CPU_ISR_jump_table[slot].format_id = slot << 2;
    _CPU_ISR_jump_table[slot].jmp = M68K_JMP;
    _CPU_ISR_jump_table[slot].isr_handler = (unsigned32) 0xDEADDEAD;
#endif /* M68K_HAS_VBR */
  _CPU_Table = *cpu_table;
thanks a lot.
Stan
URL: <http://lists.rtems.org/pipermail/users/attachments/20011026/2d1b6926/attachment.html>
