PowerPC assembler reference for GCC/GAS?
Wendell Thompson
wthompson at dsg-test.com
Mon Oct 8 15:25:16 UTC 2001
"iwe at fsmail.net" wrote:
> Hi,
> I use the Motorola PowerPC "Programming Environments for 32-bit Microprocessors" book (MPCFPE32B/AD) which lists the instructions and also has the simplified mnemonics at the back. Which mnemonics are you referring to that don't match?
Thanks for the tip. I'm using a pdf copy of the Mot book, but hadn't
noticed the simplified instructions at the end. They're what I was
looking for (la, lis, etc).
